Question about CMB T43 750 Notebook
Table Pc I first Installed Ubuntu[Linux] in my F drive which was empty. But later that evening i removed Ubuntu. After that i booted windows 3 times in a row successfully. I then put my restoration CD given by my PC manufacturer & tried booting from it. It prompted me to remove the CD from my CD drive, & i did so. And then it showed error loading OS. Again I put my restoration CD given by my PC manufacturer & tried booting from it. It prompted me to remove the CD from my CD drive, & i did so. And then it showed OS missing. I got suspicious &again booted from the Hard Disk & it Showed a blank screen showing OS missing. Please help me urgently.
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    So let me get this straight, you are trying to restore your computer to original factory condition?
  • 10 Answers
If you have an external dvd drive try using it
there's no easy answer.
Posted on Sep 05, 2009
Can I override the bios at startup so that it will recognize a new hard drive - for linux?
There should be no need to play around with your bios settings. Linux will install on a brand new hard drive as the sole operating system, or on an existing hard drive alongside Windows without any problem.
If you haven't already got a Linux distro, have a look at
http://www.ubuntu.com/download/desktop
Download whichever version of Ubuntu you prefer (LTS- the long term support version is recommended).
When the .iso file containing the operating system had downloaded, burn it onto a dvd, or install it on a usb drive.
Insert the dvd into the drive and restart or switch off/switch on the computer. The dvd will then kick in and offer you the choice of trying Ubuntu without installing, or a full install.
If you're using a new, empty hard drive just follow the on screen instructions and Ubuntu will install as the sole operating system.
If you already have Windows on your hard drive Ubuntu will give you the choice of either erasing Windows or installing Ubuntu alongside Windows. It's your choice.
Installing Ubuntu alongside Windows creates a dual boot hard drive. At start up you just choose which OS to use - Windows or Ubuntu. If creating this dual-boot system Ubuntu puts a (Linux) boot loader into the Windows OS so that Linux is recognised.
If you save the Ubuntu file to a usb drive you then have to change the bios settings so that your computer uses USB as the first boot device. Then restart your computer so that it boots in from your usb .. and Ubuntu will begin installing.
Whichever you use - dvd or usb - during the installation process Ubuntu will ask you how many GB of hard drive space it should use? You do not need to physically partition the hard drive. Linux will do it for you.
If it's a desktop PC you are using with Windows on the first hard drive and are fitting a second hard drive to install Linux on, or have installed Linux on the second hard drive .. and find that Linux doesn't appear at start up, it's because there's no Linux boot loader in Windows.
I quit using Windows many years ago.
Nov 01, 2015 | Everex IMPACT GC2500 PC Desktop
Dell Inspiron 2650 will not boot to Windows install CD after UBUNTU Linux installed on machine.
have you went onto the BIOS to make sure that the boot options are correct e.g. CD DRIVE 1st priority?
Aug 06, 2012 | Dell Inspiron 2650 Notebook
Right, i just installed ubuntu, then overwrite my vista drive, i have a vista disk but i don't know how to overwrite the linux bootloader with vista. last time i tried this if failed.
To re-install Windows Vista please do the following:
Put the disc in and restart the computer
Boot from the disc
Do a full system install
Delete your partition [contains Ubuntu(Linux)]
and install.
I recently did this last week, went from Ubuntu back to windows 7, and currently I duel-boot both Operating Systems. I hope this helps!
Please don't forget to rate :), Thanks!
Oct 07, 2010 | Computers & Internet
How can I uninstall Ubuntu from Dual Boot. I have a dual boot of Windows Vista Ultimate with Ubuntu 9.04 The specs of my computer is 2gb ram, 500 gb HDD and dual core processor 2.66ghz (E5300). I installed...
How to remove Ubuntu from a Vista dual-boot config
On my new PC I wanted (still want) to have toa go with Linux. I chose to experiment with Ubuntu. I downloaded thedesktop CD, burned it, freed up some disk space (inside Vista) andloaded up Ubuntu from the CD. After some experimenting I figured outhow to install Ubuntu in the empty disk space and it all worked fine(GRUB took over my booting (recognized Vista automatically!) and Ubuntuloaded up fine).
Then I tried to install my GPU drivers andeverything went wrong.. For some reason Ubuntu wouldn't boot anymore(failed to load X-Server or something). I was completely lost andwanted to remove Ubuntu.
This is where things start to get really messy!
Ifyou simply remove the Ubuntu partition, GRUB (Linux boot loader) willstill be on your PC (in control). It will trip out, as the Ubuntupartition will be removed.. Bad thing!
So you need to restore your Master Boot Record (MBR) for Vista (so that Vista will handle the booting, not GRUB).
Googleonly pointed me to sites that explained how to REMOVE VISTA, whichisn't what I wanted. Many sites talked about the 'fixmbr' command, butthis is really only available in Windows XP.
So how do you restore your MBR for Windows Vista?
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe /FixMbr, and then press ENTER.
That'sit. Now when you reboot your PC, Vista will load automatically... Youcan now safely boot using your Ubuntu desktop CD, to use the built inGnome Partition Manager to remove your Ubuntu partition!
Apr 06, 2010 | Microsoft Computers & Internet
I installed Ubunto 9.0 AND when it came up it said, GRUB LOAD,no such partition, then at a prompt it says,grub rescue.
If you run a dual-boot system with Linux and Windows, this has happened to you. You had to do your monthly reinstall of Windows, and now you don’t see the linux bootloader anymore, so you can’t boot into Ubuntu or whatever flavor of linux you prefer.
Here’s the quick and easy way to re-enable Grub.
1) Boot off the LiveCD
2) Open a Terminal and type in the following commands, noting that the first command will put you into the grub “prompt”, and the next 3 commands will be executed there. Also note that hd0,0 implies the first hard drive and the first partition on that drive, which is where you probably installed grub to during installation. If not, then adjust accordingly.
sudo grub
> root (hd0,0)
> setup (hd0)
> exit
Reboot (removing the livecd), and your boot menu should be back.
Only read below if Windows is now missing from the boot menu
If you installed Ubuntu before you installed Windows, then Ubuntu will not have anything in the grub configuration for Windows. This is where you’ll have to do a bit of manual editing to the grub boot menu file.
If you open the file /boot/grub/menu.lst with the following command:
sudo gedit /boot/grub/menu.lst
You’ll see a sample section for Windows, which you’ll want to uncomment and add to the boot menu list in whatever position you want it in. (uncomment by removing the #’s)
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
Note that you should also verify that hd0,0 is the correct location for Windows. If you had installed Windows on the 4th partition on the drive, then you should change it to (hd0,3)
Nov 20, 2009 | Canonical Ltd. Ubuntu
Remove linux from my computer I have a laptop with a dual boot system; Unbutu9.04 and windows xp. I need to remove Unbutu. How do I do it?
Sir,
Follow the steps below.
1 Turn on you laptop and Boot on with Windows Xp
2 After entering into the windows xp go to My computer.
3 Right click on the drive where Linx is Installed
4 Chose the option Format
5 Format the drive with the Format of FAT32
These step will lead you to remove Linux from you system.
Oct 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
I have installed Ubantu in my aspire 5050. Now I want to install win XP so that I can open MS Office from Linux
do you want to make a dual-boot system? you must have installed windows OS first and leave a non-partitioned drive in your hard Disk. Then you can install Ubuntu next, instaling it to the non-partitioned drive. When the PC boots, you will be prompted to what OS to boot.
Anyway, you can Install Windows XP in any free Drive. But it is dangerous since Windows Installer might destroy your Ubuntu installation files.
Oct 05, 2009 | Computers & Internet
64 gb kingstone not open
Always use the little icon by the clock, "safely remove hardware" before detaching
Last ditch effort if u really need those files:
try mounting it with linux. You can download a live CD, burn it and then reboot your PC and run the live CD to boot Linux you won't even have to format your PC.
I've had several external hard drives and flash drives that wouldn't mount in windows but did in Linux.
Live CD's
Ubuntu:http://www.ubuntu.com/getubuntu/download
Knoppix:http://www.knoppix.com/
Jun 10, 2009 | Kensington Electronics - Others
Dual Boot Ubuntu
1st, install windows or if you have already its good .
Then, download Linux distribution that suits You better
Download It and burn into a CD or DVD with ISO file you can use Magic ISO or other manufacturer
then Go to BIOS setup and set 1st priority is the CD or DVD drive and save and exit
and install follow the instruction of linux.
also if you chose capacity of windows or linux is to little dont worry you can make install a partition magic and resize what you like....
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Sep 07, 2008 | Canonical Ltd. Ubuntu
Dual Booting
possibly by first creating a new partition large enough for Linux OS, but does not solve your problem...try getting a VISTA startup disc from another pc (floppies if you have the drive) and startup from these.
Sep 09, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
61 people viewed this question
Top CMB Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
vojvodabudva
Masood Rasool
Level 1 Expert
Are you a CMB Computer and Internet Expert? Answer questions, earn points and help others
