For Instant Help Dial brother printer troubleshooting number 817 442 6637 or follow the simple steps:
Step 1. Print a test page from the machine: Press ? All Settings ? Printer ? Print Options ? Test Print.
- If the top of the page is not cut off or the print is not shifted, then the machine is functioning properly.
- If the top of the page is cut off or the print is shifted, go to step 2.
Step 2. Check that the rear guides on the paper tray are adjusted correctly:
How to adjust the rear guides
Step 3.Print a test page from the machine: Press ? All Settings ? Printer ? Print Options ? Test Print.
- If the top of the page is not cut off or the print is not shifted, then the machine is functioning properly. - If the top of the page is cut off or the print is shifted, go to step 4.
Step 4. Make sure the paper or media type you are printing on is within specification. Click here for more information. If the paper is not within the machine's specification, replace it with paper that is within the machine's specification.
Use paper that is between 20 lb to 43 lb. If you are printing on paper that is over 28 lb, use the MP tray to print. The MP tray can be used for paper that is 20 lb to 43 lb.
If you're printing on glossy paper that is 43 lb or more, print only 1 sheet at a time from the MP tray with back cover open.
- If you changed the paper to meet the machine's specification, go to step 5.
- If the paper that you're using already meets the machine's specification, and you did not need to change it, your machine will need service. Refer to the section below for Warranty options.
Step 5. Print a test page from the machine: Press ? All Settings ? Printer ? Print Options ? Test Print.
- If the top of the page is cut off or the print is shifted, your Brother machine will need service. Refer to the section below for Warranty options.
Yes, most likely your application's margin settings are incorrect. Try printing a test page - NOT from the application. If this is Windows, go to printers in control panel, right-click on the subject printer, choose Properties, then click the Print Test Page button. You should get the standard Windows printer test page with the logo at the top and all the printer specifics below. If the test page is also cut off, look around in the HP-provided software for any margin and/or page size settings that are incorrect, such as A4 paper when it should really be Letter size.
SOURCE: Work Pro 416 copying issues
Make sure your tray settings are correct. most likely though the paper tray lead edge registration has to be set. Make sure the tray is not set to 8 1/2 by 11 or A3 paper.
Do you want me to send you the info? Or if you have a maintenance agreement place a service call since that has to be done in diagnostics.
But I can forward that procedure to you if you provide an E-mail address.
SOURCE: Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
You can now open and print the document in Word Viewer without receiving the error message.
You receive a warning dialog box about the unprintable regions.
SOURCE: Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
SOURCE: Black line at left margin when scanning any document CX3900
Two possibilities that I can see here:
SOURCE: I need to print some cards with my printer, is it
This is normal. Practically all printers have a 'non-printable area' which forms a border at the top and bottom and left and right hand sides of the page. Whilst your software may allow you to work with a zero margin, your printer is physically incapable of printing in the non-printable area and will simply cut-off any text or images that overflow into this region.
The best solution is to reduce the number of cards on your page so that you can bring the text back within the printable area of the page. Then print with normal or wide margins and trim the excess from your cards.
Testimonial: "Thank you very much!"
