Question about Whirlpool LGR7646E Dryer
Initial gas burn does not reignite
After sits for some time, then starting dry cycle gas will burn for the initial burn (maybe 5 minutes) then shuts off. The glow coil will come on periodically but no gas will be ignited. Ideas??
  • 2,071 Answers
WHAT IS WRONG WITH YOUR DRYER?
Initial gas burn does not reignite - small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version Initial gas burn does not reignite - redarrow.gifimg src="http://i.fixya.net/uploads/images/redarrow.gif" alt="redarrow.gif" class="h_mi" /> Gas Maytag Style
redarrow.gifInitial gas burn does not reignite - redarrow.gifi Gas GE Style
Electric Whirlpool Style Version 1
redarrow.gif Electric WhirlpooInitial gas burn does not reignite - redarrow.gifion 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE;
Posted on Aug 22, 2008
Why does gas valve not turn on after initial heating during the dry cycle.
The high temp limit switch will stop the valve from coming on. Whats very important for any gas dryer is the way its vented outside. DO NOT use an vent or cap that has any kind of screen on it. This will cause a build up of lint and restrict the exhaust gases casing the limit switch to trip.
Aug 11, 2014 | Dryers
Gas lights up for about 5 minutes and then burns out. Try to turn on dryer again, but flame won't light. I let dryer sit for aout 30 minutes and turn on again - flame starts up, but will only last...
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Aug 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Whirlpool Cabrio dryer gas does not stay lit after a few minutes.
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Jan 11, 2018 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Ignites then burner shuts down then rignites over and over wont dry
Check your connecting exhaust vent for a blockage.
Remove the vent and run a 45 minute timed dry load and see if it works correctly.
Report back.
Apr 12, 2009 | Dryers
Sputters on initial startup and again also 15-20 minutes after shutoff and restart
fuel pump, clogged fuel injectors, bad gas.... could also be a timing problem among other things depending on what you mean by sputtering.... my advice find a shop that will diagnose the car for free( like AAMCO). hope this helps :)
Nov 09, 2008 | 2001 Volkswagen Beetle
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Gas valve replacemnet
to make this right, replace the thermastat and replace your coils
Apr 02, 2008 | Dryers
Dryers Logo
216 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
