Question about HP Office Equipment & Supplies
I just set up my HP LaserJet P1006 Printer and tried to print something and the paper is coming out blank. Also, there was no user guide in the box.
    Guru:
  • 1,342 Answers
Here are the basic instructions on how to set up the printer.
You can download the User's Manual and get help troubleshooting HERE
Posted on Jul 26, 2008
You must have a record. hp p1006 printer envelopes hang in print que. I have spent many hours with your staff and the problem hasn't been solved?
Envelpopes should be printed using the feed tray located in the front of the printer not through the paper cassette. Try this: Follow these steps to print on envelopes from a computer running Windows. NOTE: For specific details on formatting text for printing on envelopes, consult the help files in the word processing software. For best results, consider using a label for the return address.
  1. Click File , and then click Print . The Print dialog box opens.
  2. Depending on the software program, click Properties , Options , Printer Setup , or Preferences . The printer Properties dialog box opens.
  3. Click the Paper/Quality tab.
  4. Select Envelope as the paper type.
  5. From the Size drop-down list, select the applicable size. To create a custom size envelope, use the following steps:
    1. On the Paper/Quality tab, click Custom .
    2. Click in the Name text box, and then enter a name for the custom envelope size.
    3. Click in the Width text box, and then enter the width. NOTE: Make certain the size is in inches. Click the Use Millimeters/Use Inches button to toggle between using millimeters and inches to define the custom paper size.
    4. Click in the Height text box, and then enter the height.
    5. Click Save .
  6. Click Apply to save the settings.
  7. Click OK to print the envelopes. NOTE: An error message might display asking to load an envelope into the manual feed tray. This might occur even if the envelopes are loaded. Make sure the envelopes are loaded, and then click Continue . The product will continue printing from whichever input tray contains the envelopes.
Dec 17, 2010 | HP LASERJET P1006 Printer
I installed a new printer cartridge and it seems to be installed correctly yet when I print anything now the paper comes out blank. .
New toner cartridges have a plastic strip within the toner cartridge, which is required to be pulled out before using it. Make sure that you have pulled it out.
Hope this helps!
CreativeTECH
Nov 19, 2010 | HP LASERJET P1006 Printer
HP LaserJet P1006 Printer will not print HELP!!!
wwww.partsurfer.hp.com under the support link will have a manual to download.
Sep 01, 2009 | HP LASERJET P1006 Printer
HPlaserjet P1006 Series When printing getting a white blank streak down the middle of the page
To isolate the problem you need to do a 'half test'. This involves printing and stopping paper half way through the printer. This can be done by opening the toner door at the appropriate time. The paper should have just entered the fuser (watch out, the fuser is HOT). You should see the paper with the printing on it after removing the toner cartridge. Carefully turn the toner cartridge over and move back the door that covers the drum. DO NOT TOUCH THE DRUM. If there is the corresponding blank spot in the center of the drum, like the paper, the scanner is dirty or blocked. A can of compressed air will help here. If you have access to a different toner cartridge, you may want to try that first.
Jul 20, 2009 | HP LASERJET P1006 Printer
Hp laserjet p1006 printing jobs gets struck in printing queue
I know this problems in my part it was the hp driver.
My Solution is to use an compatible driver.
HP Laserjet 5 / or 6 standard windows driver.
After that i have not this problems.
The secound problem is that this printer have very less memory and big pages in a few times are not able to print.
Dec 25, 2008 | HP LASERJET P1006 Printer
Hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
Dec 10, 2008 | HP LASERJET P1006 Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
62 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
