Question about Sansui Audio Players & Recorders
A set of Sansui Audio System and have misplaced the System Control Cable that connect it, and will like to know if you can assist me get one. The model no. is D-E770 cassette deck, stereo graphic equalizer G-E770, digital quartz synthesizer tuner T-E770 and digital integrated amplifer A-E770.
tech48
  • 624 Answers
SOURCE: i have a 1987 model
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Posted on Sep 27, 2008
  • 165 Answers
SOURCE: tx-38/28 quartz synthesized tuner amplifier
hello surely there,s a problem in connection firs do this check your jbl even if they new with a baterry they pop up,now make sure you connect the monster wire into the outputs remember the wire is too thick make sure your getting contact in outputs...saludos
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: I need cables for a 1991 Panasonic shelf audio system
Hi Will, I searched for flat cables ,seem to no longer be stocked. If you are interested in selling the whole system let me know. I have one working condition with cables, would like to have spare units(parts). I will check one more site on cables for you.
Contact Gregg at: GreggASef1@zoominternet.net
Posted on Mar 14, 2009
caroldon
  • 17130 Answers
SOURCE: HELP NEEDED I am having trouble
In the first part use the following leads
1. Keep the Power amp as the base and connect to the Cd input the CD player, the tuner to the tuner input, the cassette deck - play output to the tape in ( amp) and Rec out of tape to the tape out(amp).
connect all the RCA sockets with the R&L in the same side of the input/output.
Now the graphic equaliser input must be connected to the Amplifier's preamp output and the equaliser's output must be connected to the Amplifier's preamp input.
Now the equaliser will work through the amp.
The left and right speakers can be connected accordingly with the polarity in order.
The second system can be connected similarily with the cassette deck, tuner and cd player connected to the input of the Amplifier using the R&L RCA sockets.
Connect the speakers accordingly and test.
Please connect each RCA cord one by one and do not mix them up.
Posted on Aug 28, 2010
SOURCE: Hello, I have found a Sansui
Hi!
I have the same deck. Did it come with rammophone or are you using your own grammophone?
I have it with original grammophone and I don't need a remote control, I don't even have it. You just turn on your grammophone and it is automatic, just place the needle on record and it should switch and play automatically. That is if you have connected the wires right (two wires for sound, one for automation, all in the same area).
If you have separate grammophone, I am assuming you just need to place two wires into the separate phono channels and it should work. There is just no automatic detection, so you have to swithc to mono manually: There is a button on the right, beside Volume control "tape to CD" or something.
To play the tape, just simply push the play button on the bottom, should work, or you could try tape to cd button off and see if it detects automatically when tape is inserted.
Currently I have it taken apart and there is tape detection system apparent. Its quite automated reciever, which sucks, because all kinds of problems appear and it is difficult to fix.
On my Sansui, the tape player starts winding slowly when pressed play button. And the tape motor seems to be on always, even when the tape is not used, and the motor is really loud. --Need to find a solution to this problem. And I hate it switch to radio/FM every time the record stops. Plus the original grammophone doesn't work correctly, it is supposed to take off the needle when record reaches an end, but it just pushes the neelde to the holder... over the record..... "screeeeech".
Posted on Dec 08, 2010
My sansui tv has an interuppted sound. How do I fix it
It's all electronics so unless you call the sansui customer care not much can be done. If you have a audio system then connect the audio out from TV to aux.in of your sound system. That way you can still hear the TV audio. I hope the audio out of TV still operational!!
Mar 02, 2015 | Sansui Televison & Video
SANSUI STEREO AV RECEIVER RZ -2605AV NO SOUND
Sansui RZ-2605 A/V Receiver no sound
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 07, 2012 | RCA Audio Players & Recorders
Connecting my laptop to my sansui 42" lcd tv via the hdmi cable, i get clear picture but no sound
Does your laptop feed sound through the HDMI connection? You may have to use the HDMI 1 jack on the HDLCD3200. Change the HDMI setting in the audio menu on the tv to DVI and run a seperate audio cord from the laptop to tv. I hope this is helpful
May 17, 2011 | Sansui HDLCD3200 TV
How do I set up my DVD player DV-X2820 it is playing the DVD but I have no picture showing on my TV
May I know the model no. of your TV, what are you using for the connections (RCA cord or HDMI)?
Let me know to assist you further.
Jdvillanueva
Mar 27, 2011 | Sansui RZ-3200AV
The tv is a Sansui HDLCD1909A I can't find a
The only audio output on the HDLCD1908 and 1909 series of Sansui tv's is the coaxial audio out jack. It only works when the tv is tuned to a digital station on the tv's internal tuner. If this won't work for you try getting your audio from your cable or sat box, etc. I hope this helps you.
Jun 24, 2010 | Sansui HDLCD1908 19 in. LCD TV
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
How to hook up a sansui classique 350 reciever to a tv
Are you wanting to play he audio from your tv through you Sansui Stereo. If you have audio outs on you tv then connect them to the aux input of the receiver. If you ae using a cable box r sat reciever you can connect the audio out from these devices to the aux or any input other than phono input of your Sansui receiver.
May 01, 2009 | Televison & Video
What cable to purchase to connect my computer to TV to use webcam
without knowing what connections you have available we can not assist you with the connection problem I suggest you try a local tv repair shop .
Nov 02, 2017 | Sylvania 6632LG 32 in. LCD HDTV
Sansui vrdvd5000- need manual
Hi seemaile,
All my searches resulted to negative which leads me to believe that there no readily available user manual for the Sansui VR DVD5000.
Sorry.
May 26, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui 42" Palsma
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
Jan 06, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
424 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
