Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Frig mod#TFX26KPDA
There is a ice sheet under the bottom drawer and daily a puddle of water will be on the floor this is on the freezer side.
  • 3 more comments
  • rodneydt Jul 28, 2008
    solution wording not clear does not match what my frig looks like there is no timer in my food department. the writer is using of he may mean or . please be correct. thank you
  • dompac Feb 01, 2009
    I have the model TFX26KPDA sidexside and have cleaned both the drain plug and hose 2 times now. The drain hole is frozen again after a week and ice is building up on bottom self again. Is there a part such as drain plug heater to keep the plug from freezing ?
  • Anonymous Mar 15, 2009
    I have this same problem unfortunately you will just have to clean the drain hole out occasionally, I usually use boiling water to clean it out and it lasts 3 or 4 month sometimes more before I have to do it again. Sorry I can't help further
  • carypie Aug 17, 2010
    I have this same exact problem - but am a little unclear of the solution - maybe the user rodneydt can provide details of their conclusion/results.
  • James Aug 28, 2012
    I had the same problem and I used some model clay and filled up the corners andall the way to the top and all along the bottom up to the drain hole to make a U shape to help drain the water to the hole and my refrigerator was too level so I tiped it back a hole bubble on the level. The door swings a little fast now if not careful but stoped the water from freezing up.
I have a refigerator with icemaker I need to know where the switch is that turns the water sedniod on
Lee Murphy EandDM@c3bb.com
GE Mod TFX20JR
Posted on Dec 31, 2008
    Scholar:
  • 93 Answers
More likely, the defrost system has failed.
There are three components: Defrost timer, a defrost heater, and a defrost bi-metal.
The timer can be located either in the food compartment, on the rear of the unit, or behind the kickplate. The heater and bi-metal are located behind the freezer rear wall (or freezer floor, depending on design). It's easiest to unplug the fridge overnight, with the freezer door open, to melt all the ice that has developed. PRIOR to doing all this, please ensure that there IS ice forming on the wall of floor of the freezer! Let me know. I hope this helps!
Posted on Jul 26, 2008
  • Femi Omojogberun Jul 29, 2008
    No refrigerator that has no defrost timer,expecially the model number you provided.
    If that solution provided did not clear to you.call service man to check it out for you then you learn more. Am not there to see exactly what you saw, I suggested base on experience.
    Check out if your drain hole was blocked, get rid of it by pouring little hot water on it till you see water driping out through you drain pan at the bottom of your refrigeration.
I keep seeing a puddle of water at the bottom of my GE Profile refrigerator. I traced the water line, and it is not coming out of that. I cannot locate any drain pan. However, I can see a 14 x 16 sheet...
the drain is stopped it is just under the evaporator a hole in the center pull out draw you will see it. blow it out .may have to chip some ice away or use hair dryer to melt
Oct 03, 2010 | Hotpoint HSS25GFT 25.0 Cu. Ft....
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Jenn-Air JCD2389G Side by Side... Problem: Leak
very common blocked drain to cure unplug appliance defrost then remuve bottom panel freezer side you will find a silver tray with a drain chnnel unblock the hole that should cure it
Nov 09, 2008 | Jenn-Air JCD2389G Side by Side...
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Kenmore side-by-side 106.52764100 Frig leaking water
Do you have a Dog ??? I had a customer who had a problem like this once.................Only to find out in the middle of the night the dog jumped up and with his nose pressed the water dispenser..If not plz check inside the freezer and see if your drain is clogged pull the bottom drawer out and look on the back wall..
PS: the pan even with a clear drain will not fill up the condenser fan with the heat from the condenser will evaparate the water after a defrost cycle
Feb 23, 2008 | Refrigerators
Water leaking on floor from under Mod#TPH21PRS;TPH21PBS
I you dont have any water hooked up for the ice maker or for water at the door, about the only thing left is your freezer drain. Look in the back under the freeser side and look for a drain... see where it drains.. over flowing? anyway water could get out from where in drains to?
Aug 21, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,146 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
