ATK. HOTKEY? - Computers & Internet
  • Gautam Dhar Mar 08, 2011
    WAS IT HELPFULL ???????
SOURCE:
2007 ATK dirt bike no spark
Hi, Ken and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and CDI box.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ATK Rider Forum View topic 260 is getting no spark
How to fix No Spark Problem on Motorcycles and Dirt Bikes
ATK Rider Forum View topic No Spark 2000 ATK 250LQ questions and...
How to test motorcycle CDI box ignition coil
ATK Rider Forum View topic Copies of 1988 ATK 406 Owners Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 12, 2016 | ATK Motorcycles
Asus keyboard instructions
try reinstalling the atk hotkey drivers.
http://support.asus.com/Download.aspx?SLanguage=en&m=Q301LA&p=3&s=583
chose the operating system. under utilities you will find atk hotkey drivers. download and install them.
Jul 13, 2014 | Computers & Internet
I use Asus laptop. after I install a new Windows XP sp3, the Fn key is not working, so i can not change the bright, the volume... How can I fix them?
The Fn function to change the bright etc is driven by the software called Hotkey software, please download the software from the Asus website and make sure you know the type of your laptop.
cheers
Apr 13, 2011 | ASUS 90-A4C1K1000 Keyboard
Hi,my laptop is Asus X42J,the problem is the Fn key,don't know why Fn + F11 and Fn + F12 cant set the sound volume,before still can...not only this 2 key,Fn+V and Fn +C also fuctionless ...but Fn + F1 and...
Hello there. Follow my steps:
  1. Go to support.asus.com
  2. Select "Download" (if you don't see a "Download" button due to being in another language, select the last item from the main menu and select "English)
  3. Find your laptop model using the wizard
  4. Select your operating system (to determine whether if it's a 32bit/64bit, go to your start menu > right click on "Computer" for Windows Vista/7 or "My computer" for Windows XP and look for a text which says "XX bit operating system)
  5. Go to the "ATK" tree
  6. Download the "ATK Hotkey Utility" thingy and install it.
Mar 16, 2011 | ASUS Computers & Internet
I have an Asus G73J. Keyboard is not backlit nor reponds to Fn + F4. Can you help? Thanks
I solved my problem by manually starting the program C:\Program Files (x86)\ASUS\ATK Package\ATK Hotkey\HControl.exe
It seems it should start automatically, but it doesn't... I added to the startup folder so I don't have to do it manually every time.
Dec 04, 2010 | ASUS 90-A4C1K1000 Keyboard
My keyboard will not light up on my ASUS G73 Laptop.
Solved. It has to do with a Microsoft update that is done through auto-updates. It messes with the hotkey drivers
Solution:
You must still have your eSupport Folder that is on your C root drive. At very least have backed it up on DVD.
Launch the install and reinstall the ATK package. That's the hotkey driver reinstall. Actually I reinstalled all the drivers just in case but I think I narrowed it down the the above package.
Reboot and you should have a backlit keyboard.
Nov 27, 2010 | ASUS 90-A4C1K1000 Keyboard
How do I turn on the back light to the keyboard of my ASUS UX50V? The light comes on mometarily during start up. The F3/F4 keys have a picture of a lighted keyboard, but do not activate the light.
Hi.. Norman
i hv bought the same laptop ..earlier i was facing this problem at day time , it consumes battery.but at night it does excellent work.
Now talk abt ur problem...
1. to on/off it use "Fn" key given near window key(near left control)
2.use Fn+F4 key to dim or off light
as u can use Fn+F5 key
3. to perminant off
go to RUN+MSCONFIG+STARTUP
and disable ATK HOTKEY driver..
NOw i have problem with my laptop(asus UX50V)..
it came with VISTA but i installed WIN7 ultimate.
now i can't open my webcam.. I dont have DRIVER for it..
if u kno help me where should i download driver for it...
rply soon...
Aug 04, 2010 | ASUS UX50VRMSX05 Notebook
Need a service and parts manual for a 1995 ATK 260.
Hi 6236068051, I am sorry you can't find the first and best tool you ever bought for your ATK but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://www.atkusa.com/parts/parts
Apr 23, 2010 | 2003 ATK 260
Computers & Internet Logo
1,380 people viewed this question
Alun Cox
