Teac lcd tv / dvd combo modle lcdv1501m the problem is it will not play dvd it plays cd ok every else seem fine could you give me some ideas please
  • markbutler1 Jul 27, 2008
    tried cleaning but it still wont play dvd plays cd ok. someone told me to check the region code how do I check this
    Thanks Benimur I tried the lens cleaner again and it fix the problem your a legend.
    Sergeant:
    Champion:
  • 347 Answers
Hello Markbutler1,
If you say it does read other CDs i dont think the lense is the problem, but anyway give it a try to clean is as Benimur say.
By the way, do you have that problem with one or more than one DVD? Have you tried the DVD that isnt being recognized on another DVD player or computer?
Posted on Jul 26, 2008
  • Santiago Vallejo
    Santiago Vallejo Jul 27, 2008
    Hello markbutler1,
    Have you ever played a DVD before on that DVD player? If so, does that DVD still works?
    If you are buying DVDs from the same country where you buy your DVD, then the region code is not the problem.
    Brigadier General:
  • 6,966 Answers
Initially, pls try using a CD lens cleaner similar to those used in computer CD ROMs. it is normally readily available from most computer shoppes. The idea is to clean the laser pickup/eye/lens. Should cleaning be not corrective, it may be necessary to open the unit for a look & see or manual cleaning the insides.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 27, 2008
    Hi again,
    • Appreciate the postback/comment. There are versions that have dual lens while most would have a single lens with dual optics for CD and another for DVD. If cleaning did not correct the problem then we have to check for other possibilities.
      if the DVD discs have been used before on the same machine and now will not play, then probable lens alignment/replacement required;
      if DVD discs are new and have not been tried before but works in other DVD players, then as you posted, regional lock;
      if ever since the acquisition of the Teac, no DVDs play, then it is possibly a manufacturing defect.
    • If the unit is fairly new, then your best bet would be to seek the services of an authorized service center or bring your concern to the attention of the point of purchase.
    • If the unit is no longer under warranty, you may need to avail of the services of a qualified professional. If you are considering a DIY (do-it-yourself), may I make a friendly suggestion, purchase a standalone DVD player. This option may be more to your advantage considering other factors like cost of repair/parts, time element.
    • and to my knowledge, it is regionally locked. The TV System is PAL B/G
Plays CDs but not DVDs.
get a dvd laser lens cleaner and use it after every 3 movies
Jun 05, 2015 | RCA 22LA45RQD LCD TV/DVD Combo
TEAC DW 552g DVD/CD rom combo drive, CD works, DVDs dont
I have your solution, but you are NOT gonna like it, so I hope you will rate it FAIRLY, even though its relatively BAD NEWS.
TAKE A LOOK AT THIS:
Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner The Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner deliver unbeatable CD speeds of 52X write to CD-R, 32X re-write to CD-RW media and 52X read as well as 16X DVD playback speeds and the drive features an advanced buffer underrun prevention technology. This disc-saving feature suspends the recording process until the buffer is refilled. No more bad discs even when you’re multitasking. It also supports EasyWrite (Mount Rainier), a new disc formatting feature that makes it easier and saves time preparing CD-RW discs for recording. Teac W552G (cdw552g/kit/b) CD-RW Burner Newbie The Teac W552G (cdw552g/kit/b) CD-RW Burner operates with: Microsoft Windows XP, Microsoft Windows...
YOUR DRIVE DOES NOT BURN DVDs, only CDS!!!
Apr 23, 2009 | Dell Latitude D520 - Celeron Intel Celeron...
My lg dvd rom play cd doesnot play dvd
DVD NOT DETECT ONLY DETECT THE VCD
PLEASE GIVE THE SOLUTION
Dec 28, 2008 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Dvd does not work
Hi Denise,
Please check your connection between your TV and DVD player. Make sure , Video Out jack of DVD player goes to Video in of your TV, The same as the Audio jack. Then try opening your , set to VIDEO , and play .......bingo....!!!!!
Good Luck,
Eriez
Apr 01, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Hacking code for Teac PL-D3200
Multizone code for Teac PL-D3200
Here is the procedure to unlock your Teac PL-D3200 to play all zones of DVD's.
Using your remote control:
1. Switch power on 2. Open the dvd tray (leave it open with no dvd in it) 3. Press "stop" 4. Press "734466" 5. Use cursor to scroll up or down until it says "Region 0" 6. Press "OK/Enter" 7. Switch power off 8. Switch power on
It will now play all region DVD's! :-)
Sep 16, 2007 | JVC TH-S8 System
Will Not Play CD-Rs Part Deux
Checked specs- YES -supposed to play MP3's. Did you try other MP3 Audio disks in the DVD? You can try the MP3 disk in your computer to make sure it is OK. If it plays in the computer, have to suspect a problem with the DVD unit - probably the converter IC.
Aug 20, 2006 | Samsung DVD-V1000 DVD Player/VCR
Televison & Video Logo
226 people viewed this question
Top Televison & Video Experts
