Question about HP LaserJet 5L Printer
HP Laserjet 5L feeds multiple pages through at a time
My HP LJ 5L pulls up to 12 pages through when it prints a page. Multiple page documents can become a mess, finding all the blank pages between the printed pages. Is there a fix for this problem?\
Thank you.
derron.mayer@gmail.com
  • Anonymous Sep 05, 2008
    matar flera papper åt gången
Look on Ebay for a seperator pad repair kit.. It's a quick and easy installation procedure..
Posted on May 10, 2009
It prob. needs an overhaul/reconditioning/cleaning to soften up or replace the rollers and rubber pads in the paper path. I imagine it needs this about every 5-6 years. Don't know if new parts are still available for this great old machine, but it's worth trying to keep it alive, at least until you change computers and don't have a parallel output port anymore ;^).
Posted on Aug 08, 2008
Laserjet 3015 will not fax more than one page a time
Open up the document feeder and clean the roller and pad with alcohol.
Jun 08, 2009 | HP LaserJet 3015 All-In-One Printer
Printing multiple test pages
Check for a sticking button on the printer itself. The big Green button will produce a test print if pushed. Also try disconnecting it from the wall outlet overnight to reset it.
Jul 27, 2017 | HP LaserJet 1320 Printer
HP laserjet 5L prints only 2/3 to 3/4 of the page of a 1 page doc
which bit is usually missing?
If it only prints the 1st 3/4 ish of the page then it could either be the page slipping a bit due to poor pick up rollers or much more likely it could be that you are sending a large file to the printer and the printer does not have enough memory.
Try printing in draft or scale down the res/size of the file you are printing
Mar 18, 2009 | HP LaserJet 5L: HP 5L Monochrome Laserjet...
Laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Mar 07, 2009 | HP LaserJet 3015 All-In-One Printer
Print page problem
Mar 06, 2009 | HP LaserJet 1015 Printer
I have an hp laserjet 3050 fax machine. When I go to fax several documents at one time, the fax grabs the whole stack and sucks them through. How can I fix this problem?
The first step is to insure that the top cover on the Automatic Document Feeder is closing properly. If it is not, the pages may multiple feed. If that is fine, then there is a pad that separates one page from the next in the ADF assembly. It wears out over time and begins to let the pages multiple feed. The part is normally replaced with the feed roller in the ADF at the same time. These are usually changed by a technician. The part #'s are RM1-0890 for the pad and RM1-0885 for the roller, you should be able to order them online.
Hope this helps!
May 15, 2008 | HP Office Equipment & Supplies
REQ:HP LaserJet 5L Repair Manual
well..those are only usually available to the HP certified field folk...
May 11, 2008 | HP LaserJet 5L Printer
Laser Jet 5550DTN printing problem
I am reading your question and coming up with 2 different thoughts.
Are you wanting multiple prints of one page, or are you wanting to print out a 5 or 10 page document?
I am not sure how to answer.
Feb 29, 2008 | HP LaserJet 5550dtn Printer
HP LaserJet 5L Printer Logo
395 people viewed this question
Ben Johnson
