How do I connect the external keyboard to the Palm T/X unit. When I try to type nothing happens and I have not been able to figure out how to connect the external keyboard to the Palm T/X. Thank you in advance. Dave Carey
    Master:
  • 382 Answers
Hello Dave,
Please check the following link on how to connect the external keyboard to the Palm T/X unit CLICK HERE
IT is explained in detail over there..Hope it helps you...!!..Thank you...
Regards!!..
Posted on Jul 26, 2008
  • 6,487 Answers
You can go check this link for the user manual and the steps on how to do that is stated http://www.palm.com/us/support/handbooks/tx/en/tx_ug.pdf
Hope that helps..............
OK button not working. What do I do?
Try to connect external keyboard then press OK button. It may work if it is a case of button.
Oct 04, 2016 | Computers & Internet
When I am typing my keyboard will jump back to any line or area in a previous sentence
Place a piece of thick card over the touchpad. This problem is frequently caused by a stray palm or thumb touching the touchpad whilst typing.
Jan 19, 2015 | Dell Inspiron 15 Laptop
The keyboard shows a connection but nothing happens on screen.
Delete device. reinstall. There may be a setting in the device manager that lets you use only one input method. So if the original keyboard will over ride? All this guess work would be eliminated if you give the os pc specs. If it's an external keyboard on a desktop then you may need to disconnect it? A laptop lets you use more than one input keyboard or wifi mini etc.
Oct 17, 2017 | FAVI Entertainment Mini Wireless Keyboard...
Toshiba laptop keyboard keeps freezing up
Plug in a USB mouse and keyboard if the problem continues, then it's a bad install or bad motherboard. If the external keyboard is fine, then it's usually a palm rest or keyboard connection problem. If this model has a nub button in the center of the keyboard, these are often problematic and can be easily removed.
Nov 09, 2012 | Toshiba Computers & Internet
My daughters key board on her lap top has started to act crazy you can't backspace and you can not type double letters you have to wait a second for it to keep typing any suggestions
First, try to connect an external USB keyboard & see if it will work fine.
If the external USB keyboard works fine, then you will need to replace your laptop's keyboard, as there is almost nothing that can be done to fix a defective laptop keyboard.
Jul 10, 2011 | Dell 0Y3740 Keyboard
My keyboard wont work. I am not able to type anything.. it was working earlier? did I lock it or something? what happened?
first of all try to connect external keyboard if its working then replace ur internal keyboard and if external keyboard is not working then then motherboard is faulty may be keyboard connector is faulty or keyboard controler chip is faulty
Mar 17, 2011 | Dell Inspiron Mini 9 Notebook
The notebook is on and all is okay except that when I try and type - nothing happens!! What should I do to restore the keyboard? I have an Acer Model NAV50. Thank you.
Sounds like your computer is looking for an external keyboard. If your mouse works go to Control panel and go to Keyboard and click internal keyboard.
Jan 07, 2011 | Computers & Internet
Logitech wireless keyboard doesn't respond
Ok, try this. Remove the batteries from the keyboard, just type anything randomly for about a minute on the k/b keys (doesnt have to make sense) Just press as many keys as you can. This will discharge the capacitors and reset the k/b. Reinsert the batteries, making sure they are in the correct alignment (try to use new batteries if you can) and connect to reciever. Press the connect button on receiver first, and then press the connect button under the keyboard.
If that still doesn't work, then your keyboard is most likely defective. Make sure you have reinstalled the k/b software first from Logitech..
May 28, 2008 | Logitech Cordless Desktop EX110
Asus eee keyboard
It's an internal problem. If ocurring after messing with the keyboard the solution is to turn off the asus, unplug the battery, plug it again and turn on. It happens in both 700 and 900 models.
May 14, 2008 | Computers & Internet
Scrambled keyboard
Have you tried cleaning and reseating the zif connector that connects the keyboard to the motherboard? Depending on how many cats and kids bang on the laptop, that can cause a problem. Another possibility is using an external keyboard and see if the same thing happens. If so, look to see if a keyboard program of some sort is running. If the external keyboard works fine, then you will need to replace the internal one, or just continue using the external one.
Oct 28, 2007 | Compaq 310640-001 Keyboard for Presario...
Open Questions:
Online Cloud Backup And Online Backup - Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Computers & Internet Logo
David Payne
David Payne
