Question about Xerox 8200/DP Thermal Printer
Error code 15.004.45:16080 for Xerox 8200
Can u please tell me what this error code would mean and if it could be expensive...
  • jstraka Sep 11, 2008
    15.004.45:389661 is this the same problem?
    President:
  • 2,072 Answers
Yes I can and I can tell you how to check to veify the problem.
That code is due to the drum heaters not operating. They simply are 2- 150 watt halogen lamps that heat the aluminum drum. One or both of them fail and cause that specific fault code.
What you want to do is shut the printer off, then the easiest way to see them is to first turn off the lights in the office or room you are in.
Turn the machine back on. Looking from the front, go to the right side of the machine, you will see some slots, its a vented opening for the exhaust fan. Just look into those slots and watch for a glow of the lamps coming on. You will not see the lamps themselves, but if they are working you will see a pretty bright glow through that slot, inside the machine. I very very seriously doubt they are coming on. I actually hope you don't see any light in side the machine. My guess is there is a 99.99999 percent chance you will NOT.
Those lamps should come on, say about 30 seconds to a minute after the power comes on. So just peek in a few times, after a couple of minutes if you see noting just turn the machine off.
They are simply 2 halogen lamps you can buy at Lowes or pretty much any hardware store for about $15 for the pair. I really recommend that if you intend on fixing it yourself, purchase if you can, the Sylvania Halogens rated for 130 volts and that are vibration protected.Although any brand of the proper wattage will work.
If you call Xerox for service, they will charge over $250 to show up and about another $250 for the heater assembly, when you really only need the 2 $6 halogen lamps. But PLEASE, if you want to try and repair it yourself, ASK ME, I will send you a step by step procedure to replace those, It is a little time consuming but not really difficult. If you have patience, I can explain it to you and you can have your printer repaired for less than $20. There is one area in specific that you have to remove carefully so as not to break a switch actuator. But I can tell you where that is and how to avoid breaking that also.
But, I can pretty much say with certainty that the lamps are your only problem, Its not a major issue at all.
Posted on Jul 26, 2008
Please , would you explain step by step the procedure to change those lamps. Thanks
Posted on Jun 23, 2009
Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 30, 2009 | Xerox Phaser 8560DN Laser Printer
Phaser 8200 error code
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Jul 02, 2009 | Xerox Phaser 8200 Laser Printer
Xerox 8200 printer error 15.004.45. How do I
If this is your first rodeo, contact www.inktechnologies.com. They can walk you through it and provide the parts.
Jun 28, 2009 | Xerox Phaser 8200 Laser Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Error Code: 15.004.45:113654
That code means the drum heaters are not working.
The good news is, yes you can fix it yourself.
The drum heaters are 2, 150 watt halogen lamps. One or both of them have blown out. If you want drop me an E-mail at rak458@aol.com
I will send you instructions how to replace them.
It would take 1 to 1 1/2 hours if you have never done it before. Lowes, Home Depot or any place that sells halogen lamps would have them.
I however, do highly recommend, if you can find them. Sylvania halogen lamps rated for 130 volts and have vibration protection. They cost slightly more, but well worth it. Besides even if you get those, you have less than $15 in the repair.
Let me know, I will send you the info. That's all your problem is.
May 06, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Xerox 8200 phaser dp
The drum heaters are out. They are 2, 150 watt halogen lamps that go bad.
That is exactly your problem. I can tell you how to replace them. Not real difficult, takes an hour to an hour and a half.
Nov 24, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
Xerox 8200/DP Thermal Printer Logo
83 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
