Question about RCA Televison & Video
I have this RCA portable dvd player, that you put in the car and it was working fine last month, but when I turned it on today, its not working. I do not know how to fix it.
  • inusha_k Jul 26, 2008
    It is running off of power cord plugged into the cigarette lighter.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is it running off of battery or a power cord plugged into the cigarette lighter?
  • RCA Master
  • 2,794 Answers
Does your DVD player have a reset button on the back or on the inside of where you put your DVDs in? See if it resetting it helps.
Posted on Jul 26, 2008
My portable rca dvd player will only keep a charge when plugged in
-Battery is too old. All charge able battery last only 2-3 year or maybe even less than that depend on how you use.
-If just a little low and keep charging then it life is short.
-If let it fully empty (dead) before charge the it last longer.
Good luck
Mai
Oct 04, 2016 | RCA DRC6309 9 in. Portable DVD Player with...
My portable dvd player won't come on
1) you must test the charger AC for DVD PLAYER, if working try to put in another DVD player, you must use the Vom FOR to measure the output voltage dc.or replace the charger.
2) if you are using batteries change batteries, clean the contacts batteries, with contacts cleaners, retight the spring contacts batteries for a good contacts.
3) if doesnot work, the problem is the power supply the trafo, filter, diode zener, bridge diodes, IC regulator voltage. etc. go to the repair shop TV for fix it.
God bless you
Jul 16, 2012 | RCA DRC629N Portable DVD Player
My RCA portable DVD wont charge. I brought it two months ago and it was working fine until 2 weeks ago. #DRC99371EB
Lithium ion batteries can be over charged. You have to try to discharge it then recharge it to retain the long life of the battery. Otherwise you have to replace the battery.
Mar 29, 2012 | RCA Televison & Video
I just got this portable dvd player about 3 months ago and now when i turn it on it will not turn the loaded dvd inside. is this fixable, or what should i do?
Unfortunately no! the problem is in the laser pickup assembly. If you still have warranty now would be the time to use it, if not! far cheaper to replace the dvd player.
May 20, 2011 | RCA DRC6309 9 in. Portable DVD Player
DvD Player will not play disc
The discs got warped due to heat.
Sep 05, 2017 | RCA DRC629N Portable DVD Player
Attempts to load then reads no disc
The problem is with the lens assembly. sometimes you may have to replace it(lens assembly) or optical pickup
Jul 03, 2009 | RCA DRC629N Portable DVD Player
GPX portable dvd player does not play on bigger tv with rca cable
You have to buy the $15 video cable from GPX. I tried several differant cables including RCA to S Video as a last resort. They say theirs is propritary and I now believe it!!!
Jan 01, 2009 | GPX PD708B Portable DVD Player
Marvin
I have the same DVD player and it no longer works. The battery worked just fine a month ago when I used it last, but now the player won't power on. It appears to be a problem with the "on" switch.
Would you like to buy the battery for $10 plus cost of shipping from Georgia??
You can email me at terri1butler@hotmail.com.
Oct 23, 2008 | Durabrand DUR-1700 Portable DVD Player
RCA Portable DVD palyer
only thing you really can do is open it and check the fuses.
Dec 10, 2007 | RCA DRC6300N DVD Player/VCR
Televison & Video Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
