Question about Kenmore Oasis HE 27082 Top Load Washer
Crazy washing machine
The only good news is, I got this 1 year old machine for FREE. It actually works great for the most part, but now and then when it starts to wash a load, it gives an F1 code. What the heck does F1 even mean?? So here I am with laundry just piling up, any suggestions?
  • Anonymous Jul 30, 2008
    SEARS SOLD ME THIS MACHINE KNOWING THAT THIS PROBLEM
    EXISTS, THEY REPLACED THE WASHER 2 TIMES. I GET THE F51, AND HAVE TO RESTART IT 3 OR 4 TIMES SOMETIMES DUMPING THE
    WATER OUT--THEIR SERVICEMEN ARE IDIOTS.
    I WANT MY CREDTI CARD CREDITED AND TO RETURN THE MACHINE.
    SOMEONE PLEASE HELP!!!!!
  • Anonymous Jan 02, 2009
    I have had the same problem with my washer. I am so glad that I thought to research it before calling Sear repair service. I took the advice of Lumpy 816 and tore into the washer so far I have not heard the beep.
  • 246 Answers
F51 error code is beacause the computer board did not receive input from the motor on the bottom. Unplug the washer, pull the machine forward and tilt the machine back. On the bottom you will see a large white wheel with a silver allen screw in the middle I think it is a 6mm allen wrech that takes it off. Once you remove the screw and drop the white wheel, there will be a large coil of wires with 4 5/16 screws holding it on, remove these screws and drop the coils. On the right hand side you will see a connector with three wires , unplug it. Use sand paper or a scraping tool to clean all 3 male sides of the connectors. Reverse process to re-assemble.
Posted on Aug 09, 2008
I have had the same error code message. I bought my washing machine in March 2006. I called 1-800-4-my-home (Sears repair) since I have a 3-year warranty. The gal said they don't really need to send out a repair person. She said it's most likely a computer malfunction. She said to unplug it for 2-minutes and plug it back in or you can turn off the breaker to your laundry room for 2-minutes and flick it back on. If that doesn't help, you may need a technician to come out and look at it. Hope this works for you!
Posted on Jul 29, 2008
How to check coil on 6.25 hp briggs and stratton mowwer
If the engine is less than about 25 years old then it will have Electronic Ignition .. i.e. no points & condenser like the old days.
So if it is electronic ignition then the coil is actually an Ignition Module, which means that the coil AND it's electronic trigger module are integrated into a single sealed and non-serviceable unit. But that is good news when you want to check it.
Simply place the machine in a relatively poorly lit place (or do it at night) and remove the spark plug and place something metal in the plug lead then set that near a metal part of the engine (but AWAY FROM THE SPARK PLUG HOLE !! ) so that there is a 6mm (1/4") air gap. Then crank the engine over with the throttle in just above idle position. You should see a "cracking blue spark". If not, coil is cactus. Simple as that. That's the great thing with B&S ignition modules .. they work or they don't.
Nov 04, 2013 | Garden
Leaking like crazy and only 2 1/2 years old. Where are the screws so I can take the bottom panel off?
Their are 3 screws holding the front lower panel onto this unit.If you can tip the machine back some and put a block underneath it will help you see and remove the screws ,I believe they are 1/4 inch or t15 torx... If the unit is leaking that bad before tearing apart carefully run your hand around the lower section of the door boot (rubber) and inspect for a tear or a hole Hope this helps you out GOOD LUCK
Sep 04, 2010 | Kenmore HE2 Plus Front Load Washer
The washer works as far as washing the clothes but makes a terrible noise when spinning.
If the machine is a few years old it could mean that the rear seal has worn and allowed water into the spin bearings. If the drum feels loose, it means ther'es free play in the bearings as well. Not good news..It's a major job and will need a wokshop...........Nomess
Apr 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't complete normal cycle, but will complete heavy duty normal cycle gives errors codes of "sd", and "f21". have cleaned trap, and it works for next cycle, then errors out again. But Heavy duty works...
GOOD NEWS
actually SD means SUDS, it maens that your using too much soap,
when you clean out the rap your cleaning out the rest of the soap,
anyway, if you cut way back on your soap, i usually sugest 1 tablespoon for these models works just fine
try one empty load and no soap
watxh the suds appear in the wash cycle
remenber you bough this machine for water savingfs
1/6 the water 1/6 the soap
Oct 24, 2009 | Whirlpool WFW8500SR
My Whirlpool Duet shrinks my clothes.
If you did not have good success with the unit - I would advise against getting another one.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch nexxt 800 washing machine
It appears your touch panel has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Jan 27, 2009 | Washing Machines
Dryer switch fill washer ??
Sounds like an Electronic problem.
You should call service.
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Try :
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Neil
Aug 13, 2008 | Frigidaire FEX831CS Top Load Stacked...
IW811 eco intuitive 8kg
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Jul 19, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Bosch Axxis Front Load Washer
This video will show you how to change a door seal on this Bosch GLTF2940ES front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Aug 20, 2007 | Frigidaire GLTF2940ES Front Load Washer
Water leaking
Leaking pump or drain connexion most likely you will have to get under to check it out. Put a several sheet to news paper under the machine and pull it out as it stands to see where the water is coming from front/back/sides Do a wash and repeat. But you will need the service of an engineer I guess unless you are good with a wrench.
Aug 05, 2007 | Kenmore 43142 Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
81 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
