Question about Amana ABB1927DE Bottom Freezer Refrigerator
IceBoxnot getting cold
I have a GE Icebox and the freezer is running none stop and causing it to freeze and the icebox is not getting cold. I have turned it off and let it thaw but it didnt fix the problem. Top portion of frig not getting cold, bottom not gertting cold and ice is building up on coils at back of bottom freezer, Can see ice through vent at back of bottom freezer. Thawing out helps but ice eventually comes back.
  • buzzard bait Aug 29, 2008
    Thanks tommytgee, I replaced the defrost thermostat and it now works fine. Your response was a day late, but appreciated just the same.
Sounds like a similar problem I have, but with a top loaded freezer/refrigerator. I took the back panel of the freezer out (carefully so as not to break anything). I discovered ice covering everything; coil, defrost heater, and perhaps a defrost timer (I didn't see one). I suspect (according to what I've been able to find on the internet without having to pay for a response) that the defrost heating element and/or defrost timer are defective. I only use this 4 yr old refrigerator seasonally, so I don't mind having to manually defrost the freezer. I will try to get parts in the states when I return in the fall. This doesn't tell you how to repair the problem in entirety; but it may give you a hint and possible temporary solution. Oh, I used a hair dryer to melt all the ice covering the above noted freezer parts. My refrigerator is working just fine; however, I'm sure that it'll build up with ice once again. I'm leaving in 6 weeks, so I don't care so long as I know that I can remedy the problem for now. The article I read recommended using a volt meter tester; that I'm not familiar, it may very well allow me to determine which part is defective. The heater coil is about $25, I didn't check on the timer. Try this site: http://www.applianceaid.com/defrost_cycle.html . Good luck. Tom
Posted on Aug 27, 2008
Icebox Not cold
What is the model number?
Oct 27, 2012 | Frigidaire Refrigerators
The frezzer is freezing up and the icebox is not cold. the fan in the freezer is turning. model 106 74262400 serial ER 2922094 type 22TFA
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | Kenmore Refrigerators
Refrigerator is freezing up and not cooling the icebox
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
yte
Apr 11, 2010 | Kenmore 72102 / 72104
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
Fridge stopped cooling and freezing and making ice all of a sudde
is the unit free standing ? if so have you defrosted it using hot water.please dont.need more info ............
Feb 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not getting cold, ice maker not making ice
It sounds like it is doing some cooling. Check to see if your evaporator fan is running and there is not ice buildup on your evaporator (indicating a defrost issue, common on ge refrigerators, usually heater goes bad), you would either see ice on the back wall of freezer or if you take off the back wall you will see lots of frost. Also check if your condensor fan is running and clean the condensor. The compressor is running since it is getting down to 27 but if it is not being cooled it will shut down. Another common problem on the ge refrigerator is the main board contacts going bad and not running the compressor. If your compressor is running the whole time and none of the other conditions exist it sounds like you have a leak or restriction in the refrigerant or sealed system.
Dec 13, 2009 | GE Profile PSC25PSWSS Stainless Steel...
First freezer stopped freezing. now icebox is not cooling at all and freezer is warmer than inside of icebox
You have a bad defrost system in this unit. Call or emailus with the brand and model number and we;ll get the correct part out to you right away to get you cooling again! We look forward to working with you and hope to hear from you soon.
Oct 06, 2009 | Refrigerators
Problem with everything freezing inside icebox no matter where the control is set.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | Refrigerators
Ice box
you have a leak or the compressor is not starting,you need to pull the frig. out and see if you see any oil on the lines this would mean the freon is leaking out,also put your hand on the comp. and see if you feel it running if not you would need to go to your local appliance part store and get a 3in1 start kit and install it ,it's easy the directions are to the part,hope this helps you-mike
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Ariston fridge freezer - drips water
I'm afraid if the door isn't sealing properly and staying cold then the ice will always be melting somewhat and dripping. Is there ANY way to glue/epoxy/fiberglass that part back on or repair the door, etc.? If you can't get repair parts either you may be stuck with a broken cooler. It seems like some shop (boat shop, auto bodyshop, etc.) should be able to repair those items with fiberglass or something. I guess it just depends on the cost to repair verses to buy new again.
Jan 23, 2007 | Ariston Technologies CBC96 Wine Cooler...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
41 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
