Question about Samsung Prostar DCS-24B-LCD Corded Phone
Setting incoming calls
I am having a problem setting up names in the system. Specifically, when someone calls in and the answering machine picks up, the recorded message tells people to punch in the first few letters of their parties name, and it will not accept the name.
    Scholar:
  • 108 Answers
The Directory is controlled by the Voicemail and one of the options in the set up of the mailboxes is Directory Name ( # 7 3 ). This has to be set up for this feature to work properly.
Posted on Jul 27, 2008
Is it normal for my AT&T CL4940 phone's display to show the number of "missed calls" even though the phone's answering system is not on (because I use a separate answering machine to record calls)?
It's completely normal. The phone is simply saying it detected an incoming call that it didn't answer. Try setting your other answering machine to pick up immediately, perhaps that will stop your phone from "seeing" an incoming call.
Sep 27, 2017 | AT&T Lands Phones
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Our phone does not ring with incoming calls,but call goes to the answering machine
Some of these contraptions have a setting in the menu where all incoming calls will be routed to the answering machine or after so many rings the answering machine will turn on.  Find the setting and turn it off.
Nov 05, 2009 | Audio Players & Recorders
Our brother intellifax 4750e fax machine will not
It is probably set to manual receive, meaning you have to pick up the receiver, then hit start to receive the fax. I'm sorry I don't know specifically where to find this setting on your model but if you can find it in your menus, you should be able to switch to auto receive to eliminate this.
Oct 15, 2009 | Brother Office Equipment & Supplies
My fax goes off periodicall when a call comes in.
It means that your fax machine is "answering" the incoming call before you pick up the handset. Usually, the factory setting on the fax machine picks up after two incoming rings. There are three ways you can address this issue: 1.) You can either change the number of rings to, say, five incoming rings to give you enough time to answer the phone before the fax machine picks up, or 2,) you can find out if your fax machine has a feature that allows for the voice hook "click over" that will allow you to override the fax when you pick up your handset, or 3.) turn your fax machine off until you need to send a fax.
If you want to investigate number 2.), then you'll need your operator's manual.
Good luck.
Aug 28, 2009 | Office Equipment & Supplies
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
Canon Pixma MX300 fax vs voice
I haven't checked the manual specifically but if you are "manual-less" here's a link
Dec 27, 2008 | Canon MX300 Office All-In-One Printer
Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Samsung Prostar DCS-24B-LCD Corded Phone Logo
90 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
