Question about Dyson DC15 Animal Bagless Upright Cyclonic Vacuum
Dyson 15 animal
Bottom has suction but the brush will not spin
  • 6 more comments
  • downloader Sep 26, 2008
    Brush only spins intermittently - suction perfect though
  • Dob3 Oct 04, 2008
    I have exactly the same problem .It has great suction but it only spins randomly.
  • terribet1950 Nov 28, 2008
    I HAVE THE SAME PROBLEM -- CANT FIND MY USER MANUAL WHERE CAN I DOWNLOAD ONE
  • ErichG Feb 01, 2009
    brushbar doesn't spin though good vacuum.
    Have taken apart. No belt. Brushbar is driven directly by
    Johnson U-5640 motor. http://www.johnsonelectric.com/mediando/...
    Motor is 120 VAC nominal drive, but motor output of circuitboard,
    Dyson prt no. 09513, is only 15 VAC. Is something on circuitboard blown
    and how can I get a new one ? Dyson repair and support webpge for this model doe not work.
  • petersangels Mar 01, 2009
    Dyson DC15, Same problem. I have tried a new Brush motor but still it does not work. There is no belt on this model so don't try looking for one, like some people are advising. The Brush motor has replaced the belt drive.
  • rjh21 Mar 01, 2009
    Same again. Brush does no spin at all (worked fine yesterday :-( ). Have taken brush head apart and cleaned. No belt as reported elsewhere. Motor looks and smells fine, but no voltage reaching it (tested with multimeter). Haven't dismantled circuit board enclosure as my hex screwdriver is too short!
    Seehttp://www.espares.co.uk/diagram/dyson/d... for exploded diagrams.
  • Al_Cloud Apr 11, 2009
    Same as others... brush spins randomly or when vac is positioned a certain way. Dyson online help doesn't offer solution.
    Same problem... intermittent brush. Mine is the DC15 All Floor model. Dyson online help doesn't offer solution.
So I was having the same problem with no brush movement. Found this inductor exploded and wire melted off for the brush motor; However, this will allow the suction motor to work. I didn't smell it as much becaues the circuit board is inside the ducting before the filter. I have been looking for a replacement board but haven't found anything so tomorrow I will replace the bad parts on the board instead. Good luck to everyone else with this problem!dyson 15 animal - 2c752e0.jpg6da67b0.jpg
Posted on Jul 22, 2010
  • 65 Answers
Broken belt. when removin the cover to replace the belt make sure you dont break the plastic. its thin and breaks easily
Posted on Nov 30, 2008
2 Suggested Answers
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: My Dyson Animal has zero suction from the wand or
    Hi there, I'm sorry to hear you're having difficulties with your DC07. If it doesn't seem to be picking up as well as usual, it's possible that there's a blockage in the system - I'd also recommend giving the filter a wash. The easiest way to check for and remove any blockages is to follow the steps shown in our online support guide: http://www.dyson.com/support/help.asp?article=4&product=DC07-ANIMAL_US Under normal use, this should be done at least once every 3-6 months. Use cold water without detergent, and allow up to 24 hours for the filter to dry completely before replacing it. By clearing any obstructions and washing the filter, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you, and to recommend the best course of action. Kind regards, Jack Dyson Online Customer Support
    Posted on Sep 16, 2011
    Testimonial: "U da man Jack!"
    My dyson dc35 animal brush spins very slowly. Brush is clean and hair free, could it be the small motor
    There shouldn't be a motor in the brush. The brush is powered by the suction on the hose. Check the suction on the hose. The vacuum itself might need to be cleaned. If the suction is a problem and you have cleaned the vacuum I would contact dyson support to see if they can replace your vacuum. http://www.dyson.com/support.aspx
    May 23, 2016 | Dyson Vacuums
    Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
    I can think of three things that could be wrong.
    The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
    The internal drive belt is worn, or the nylon bush that it runs on.
    The clutch is worn out.
    The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    My Dyson 14 Animal seems to not have the suction
    Hi its Darran at Dyson.
    Firstly check that the brush bar control on the cleaner head is in the correct position. You may have switched the brush bar off the last time you used it or the dial may hav got knocked when you vacuumed under some low furniture.
    If this is in the correct position but the brush bar is still not turning, switch the machine off and remove the soleplate by turning the 3 fasteners on the base of the machine and checking for blockages and remove any threads or hairs around the brush bar.
    I would recommend washing the filter if it hasnt been done for a while.
    You may find it useful to follow the blockage procedure and filter washing instructions in your user guide, however if you no longer have this available you download a replacement for free via the support section on our website at www.dyson.com.
    I hope that this information is useful to you.
    Kind regards
    Darran
    Dyson Customer Service
    Apr 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
    My dyson DC07 has no suction. motor runs, brush spins, just no suction.
    hi..the reason to this problem may be the bottom pieces
    might not have been fully seated.Take it apart and put it
    carefully back together.This will solve the issue.
    check it out..
    thank u..
    kindly rate my response..
    Jun 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Suction loss on dyson animal
    Hi.
    Keep the axe on hold try this first.
    Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
    Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
    Remove hair from brush roll using scissors.
    Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
    Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
    Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
    If its stiff to rotate you will need new roller.
    Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
    Now check the long flexi hose & metal wand for any obstructions.
    If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
    On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
    Chris...
    Sep 21, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Dyson DC15 Animal Bagless Upright Cyclonic Vacuum Logo
    710 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
