Hoover Elite 1210 washing machine not spinning (brake arm problem?)
The machine drains but not spin and when I opened the panel, I found that brake arm latch stay 'locked' preventing the drum from spinning. I removed the brake arm spring and the drum spins freely. Please advise how to fix it and now I have an added problem not knowing how to fit the brake spring onto the brake arm (which way should the spring be facing !!!??) Please help..........
The brake arm and brake spring pictures can be found on Page16 of the contents on the following website (Parts HP001 and HP002):
http://www.stokes-aus.com.au/StokesAP/downloads/OzSpares_Sect1.pdf
fanny
  • 146 Answers
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Posted on Nov 03, 2007
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
  • 135 Answers
SOURCE: water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Posted on Nov 15, 2008
  • 1114 Answers
SOURCE: Hi i have recently bought a sealant kit for my
The first step is to replace the receiver dryer/ accumulator to ensure that no moisture from the old unit enters the system after the sealant is introduced into the system.
The next few steps pertains to extracting the old refrigerant in the system, called recovery, and placing it in a sealed container. The refrigerant is not supposed to be released into the atmosphere. The second step pertains to extracting all moisture in the system with a special vacuum pump. Moisture in the AC system impedes the flow of the refrigerant.
These steps are typically performed in an auto shop, and it's pretty much standard procedure.
Backyard mechanics do not necessarily have this type of equipment, but they make do and hope for the best.
Hope this helps.. I would appreciate a rating, Thanks. (Good Luck)
Posted on Aug 02, 2009
Hoover elite 700 washing machine won't spin
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
# A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
# 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
# 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
# 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
# 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
Regards.
Jan 05, 2012 | Hoover Washing Machines
My Hoover elite 920 goes through it's cycle put
the pump is bad. not worth the repair bill. get a new washer
Nov 03, 2011 | Hoover Washing Machines
My Hoover Elite 1210 toploading washing machine seems to make a horrible off balance sound on the spin cycle - even when there is a small load on. What can I do to fix it?
Could be bearings or more likely the concrete weight at the bottom of the drum is loos give it a shake from under to check...Good luck
Feb 09, 2011 | Hoover Washing Machines
Kenmore 80 series has loud banging sound during the spin cycle
I had a washer that at the beginning of the spin cycle it was fine, but when the water was half drained it would begin making a banging noise. When the draining reach the bottom and the spin speed increased it was fine. Finally found the problem - What happened was the tabs that hold the control arms for the brake had loosened. During the spin cycle especially in the middle of the cycle (when torque was at the maximum and speed was at medium. The brake spring would flex out due to compression and hit the some extended metal tab on the brake housing. Once the speed increased and the torque reduced the spring no longer hit the housing tabs. Fix the problem by bending the tabs that hold the brake control arms in place to better hold the control arms in the proper location.
Jan 19, 2010 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
My front-loading Hoover washer/drier (Softwave 1100, Model A8754). Will carry out the wash cycle but not go into spin cycle and thus door will not open. Checked for blockages and none found. Can you help...
Door will not open if it has water in it.
Lay hose down to get rid of water, then you can open door.
Try the spin with no water in, if it spins, then you have a draining problem
Nov 22, 2008 | Hoover Washing Machines
HOOVER 510 PREMIER WASHING MACHINE ABOVE THE BELT SHAFT THERE IS A PLASTIC COG WHEN THE WASHING MACHINE IS ON WASH CYCLE IT SPINS FINE ONE WAY THEN ON THE REVERSE SPIN THER IS THIS ORANGE LEVER THAT MAKES...
I imagine you've bought a new machine by now? The plastic gearcog is the clutch housing. The arm that clicks is part of the brake lever. On these models, the brake lever is supposed to hold the clutch in place during the wash cycle so that it slips in both directions to get a forward and reverse wash. On spin, the lever moves away releasing the clutch and gearbox brake and allowing the bowl and agitator to spin together. The brake lever wears and allows the gearbox to slip during the wash cycle. When this happens, the clutch housing will "ratchet" past the brake lever tongue. this causes the "clicking" noise in 1 direction.
Oct 17, 2008 | Hoover Washing Machines
Hoover elite 1210 won't progress to the final 'spray and spin dry cycle'.
Hoping to be of help after the spin dry wouldnt work on our hoover elite 1210.
It would do the wash cycle fine but as soon as it needed to drain, it wouldn't.
My handy man (Husband) is great at fixing things and opened the front panel by undoing the screws.
Near the motor on the bottom left, there is a wheel/fan looking thing.
(Turn the machine off first)
He tried to spin the wheel but it would only move clockwise and not anti-clockwise like it is supposed to.
So he gave the fan a few spins clockwise before giving it a gentle pull outwards in which it loosened the wheel and was able to move anticlockwise again.
We then turned the machine on and it started spinning and draining the machine.
This machine is a work horse and I refuse to get another. They don't make them like they used to!!
Mine has a leak and we use a drip tray underneath at the moment. So long as it works. I am happy.
Hope this helps someone else with the same problem.
Sep 21, 2008 | Hoover Washing Machines
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Washing Machines Logo
293 people viewed this question
Top Washing Machines Experts
