Question about Fisher and Paykel GWL11 Top Load Washer
Washer wont turn on
The washer wasnt used for a couple of months. When I plugged it in the washer lights came on and went off again right away and wont turn back on. I've checked the common sense things like the fuse box and the plug in works. The cord is connected tightly to the unit. Is there a reset button or a fuse in the panel I'm not seeing? The washer worked fine until now. Please Help!!
  • 1 more comment
  • AussieFixer Jul 26, 2008
    Exactly the same problem, but on a Smart Drive 703. No fuses - power in the right places but just won't turn on.
  • grandma10 Jul 31, 2008
    I've figured out how to solve my problem. I'm buying a washer and dryer with a name I'm familiar with. This also doesn't require you to pay an "expert" online to try and figure out what the problem is. I'm learning Fisher and Paykel quality is very low and the price is very high. I have called repairman to look at the washer and 2 of them said it will cost more to fix than the things worth. This set isn't 2 years old yet and is actually used in a second laundry room for when the kids and grandkids are home. I have an Admiral set that is used constantly for 5 years now and no problems. I will go with Admiral or whirlpool for my lifetime. Sorry Fisher and Paykel your product just isn't what you claim it to be.
Serive enige soon light
That light just means the emission levels are too high,doesn't mean there is a big problem,a bad plug wire or even a loose fuel cap will turn on the light,
Dec 22, 2013 | 1999 Mercury Tracer
I have a 1991 nissan primera 4wd, I have been fixing it up for a couple of months and i went and took it for a test drive the other day, that was when i realised my speedo wasnt working at all, it wasnt...
check connection at the trans housing for speedo problem as for lighting ahhhh what a headache so many problems from connections to bulbs or fuses
Sep 18, 2013 | Cars & Trucks
I have been using presario CQ50 compaq laptop, it was working fine but as time went on the laptop felt as though it was starting to overheat and would randomly turn off, i wasnt sure if maybe it was the...
are you going to spend hard cash on this junk
its old and worth Zero
now
try a new battery, oops those are expensive.
i see working
presario CQ50
for $30 working
not working worth nothing
its worth at best the cost of potted plant.
why fool with it>? or spend cash on any COMPAQ.?
got to "GOODwill" fine a 10 year or newer system.
best advice of all that. one that works too.
Mar 28, 2017 | HP Compaq Presario 730US Notebook
Pilot light wont stay onfor outside pool heater. Gas co made a service call & relit the pilot light it went out again 4 days later.
There is a thermo couple that keeps the gas on. The pilot light bracket has a small screen where the gas comes through that can get clogged and cause the pilot light to burn away from the thermo couple which would cause it to think the flame has went out and shut the gas off. Or the thermo couple has went bad itself. If you try cleaning the screen use canned air and gently blow it through the orfice once you have taken it off. If you don't know what a thermo couple is or looks like here's a picture of a generic one that will give you an idea. Usually there's a bracket that holds this in place. f1b528a.jpg
May 09, 2010 | Pool & Spa
No power, hard starts
Have you replaced the fuel filter, spark plugs and wires? A plugged fuel filter will cause a fuel pump to go bad because it works harder to pump. It also may cause less pressure. Plugs, wires cap and rotor will cause lack of power and fail you on a load if they haven't been replaced for a while.
Jan 11, 2010 | 1996 Chevrolet Tahoe
Stalls when stopped at a light. This problem goes away and then comes back. Replaced plugs and wires. Problem went away for a couple of weeks. Then it came back worse. Mechanic traced problem to the...
Inspect and clean the MAFsensor located in the intakt duct. It measures the air density and vvelocity of air and communicates with the computer for proper fuel ratio provision. It can be cleaned with CRC electrical cleaner spray. Do Not rub, brus, or otherwise touch thhe sensor. Just wash thoroughly and ley air dry. No compressed air. Good luck, Ned.
Sep 11, 2009 | 1993 Toyota Corolla
Nokia n70 wont turn on.
it sounds like its been stolen or hardwear is faulty
May 21, 2009 | Nokia N70 Cellular Phone
1991 nissan primera 4x4 car
I have a 1991 nissan primera 4wd, I have been fixing it up for a couple of months and i went and took it for a test drive the other day, that was when i realised my speedo wasnt working at all, it wasnt lighting up when i turned on my lights and the needle wasnt moving but the taco and everything else on the dash is working perfectly fine. How do i fix it?
May 07, 2009 | 1990 Nissan Pulsar
Fisher and Paykel GWL11 Top Load Washer Logo
83 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
