Question about Asko T731 Electric Dryer
No led light how do you check fuses?
How do you check the fuses on the T731
  • suzfrench Jul 26, 2008
    There is no intake on the rear of the T731 ASKO. It appears the air intake is on the front left. I can't remove it there are no screws etc.
    the location on the rear only has the 220 wiring hookup no fuses that I could see.
    Master:
  • 382 Answers
in the back of the dryer there is a air intake spot that was so full of lint and stuff..Yeah Exactly open the back cover and you can exactly find the fuses below the air intake spot !!!...Thank you...
Posted on Jul 26, 2008
  • 13,433 Answers
Unless im mistaken they are in the back and cover needs to come off, see this picture.
  • 2 more comments
  • Ekse Jul 26, 2008
    Akso washers rated 208-240V have two internal fuses of 15 A each, yours might have one.
  • Ekse Jul 26, 2008
    Yes they are in the back of the dryer.. should be right there.
  • Ekse Jul 27, 2008
    do you see a metal box on the right hand top back area, if so the fuses should be there.
  • Ekse Jul 27, 2008
    I was told that The fuse is in a fuse holder which is in an attached metal box on the right hand top back area.
How do i replace the belt on my asko t731
open up the back panel it is usually right ther and easy to do
Sep 07, 2011 | Asko T731 Electric Dryer
My dryer stopped working this morning. The light to the on switch is "on," meaning it's red. But everything else looks dead: The start button doesn't have a light. And, the display panel is...
If it there is power in the system (red light on power swithch),yet the dryer does not run - with a totally blank LED screen (no error message), the controller board may be out. You can snap in a new one (remove the top of the dryer, take picture to make sure you know where the wires go) remove from clips n replace. Only thing, it'll cost you $220 to buy a new one. Try repairclinic.com - if it doesn't work you can return for full refund.
Mar 11, 2011 | Asko T731 Electric Dryer
No light display
evidently. there is/are fuses on the back of the dryer, I am assuming one of those may be blown. Here is a manual I found, it does not have a wiring schematic on it, so I am assuming that Asko is the same as any other manufacture, meaning they put the schematic in the top left hand corner of the control panel on there dryers. Should be 6 screws. I hope this helps Tim:
http://dl.owneriq.net/e/e7d9f38b-5a0e-6344-6949-46091be9e970.pdf
Dec 25, 2010 | Asko T731 Electric Dryer
Asko T731 Electric Dryer - where are the fuses on the back of the dryer?
Welcome to Fixya.
Before starting...
**Turn off your breaker at the home service panel, it should be a 30amp switch or unplug it from the wall...safety first**
The fuses are at the back located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown.
You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, reliableparts.ca etc.
Asko part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
Aug 05, 2010 | Asko T731 Electric Dryer
ASKO T731 Dryer - Air is not warming up.
same thing has happened to me...please help
Dec 05, 2009 | Asko T731 Electric Dryer
Asko T731 sensor suuts off the dryer prematurely
you need chek are clean folow:
1-line chute assembly.
2-housing blower.
3- pipe duct .
Oct 05, 2009 | Asko T731 Electric Dryer
Asko T731 Electric Dryer Logo
229 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
