Question about E-Machines eMachines Desktop PC
Won't boot HI, I have power but that is all, it won't boot up and no power to the keyboard
  • mrsmack Jul 26, 2008
    no i haven't
  • Gary Luis
    Gary Luis May 11, 2010
    have you changed the power supply recently?
    Scholar:
  • 162 Answers
Ok, so you have power. Are there any lights on in the front? I'm assuming by power that the powersupply fan must be coming on when you either plug it in or push the power button.
Posted on Jul 26, 2008
My Toshiba Satellite A105-S2031 laptop won.t boot up. When I turn on the laptop the two small lights below F 10 and F 11 light off then the computer turns off.
Try removing the battery (in case it's shorted), plug in the power adapter and boot to bios (using F2, F10, etc). Be sure there are no USB memory sticks connected, etc. If you are able to boot to bios, great! Then, it's a matter of eliminating the root cause: either battery or hard drive. If you don't boot to bios, then you're most likely facing a hardware problem. It may be as simple as an unplugged cable.
If you can't boot to bios, consider connecting an external monitor to rule out LCD display problems.
Aug 09, 2013 | Toshiba Satellite A50 Keyboard
Keyboard locked
If they are PS/2, power off make sure that they are not plugged into the wrong port, they will fit....but won't work that way.
If they are USB, try booting into safe mode and see if they work there
Pressing [F8] repeatedly on boot is how to get the Safe Mode options to appear, then use the Arrow-keys, (up or down,) to highlight a Safe Mode option, then press [Enter] to select it.
Tallon41
Sep 15, 2012 | eMachines ET183107 Desktop PC Intel...
Compaq presario won't boot caps lock blinking power button on
hi
maybe you have change the keyboard , it is failure
Sep 05, 2012 | Compaq Presario Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
M17x won't power on but keyboard lights work
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
May 21, 2012 | Alienware PC Systems Area-51 m17x Notebook
My hp p6620f does not boot at startup
Hi Netty,
Firstly remove the RAM memory from the main board, clean it with an anti static spray and replace it making sure it sits firmly in its slot.
Try to turn on your PC again. If it still won't switch on you may have to replace the power supply. First check this by plugging in a power supply from another working PC.
Best wishes,
Graemevm
Jan 15, 2012 | HP Computers & Internet
Computer won't boot up
To boot up
1)switch on the power button
2)when start press F2 until bios is not appear
3)go to boot menu and select your dvd or cd in first boot menu
4)press F10 for save and exit
5)it will restart before it you have to insert installation disc to dvd or cd drive
6)when appear "press any key to boot" then click ENTER button of your keyboard it will automatically boot.
thanks
Aug 14, 2011 | Toshiba Computers & Internet
Keys won,t work on keyboard
In regards to your problem you might want to try some of this steps
1. Check the keyboard cable, try to reconnect the cable and check if any message will pop up to verify
the keyboards connection
> you can restart the Pc then check again once it booted up
2. Be sure the numlock is on
3. Check if your PC detects your keyboard by checking it on Control Panel
> Click Start
> Choose Control Panel
> Go to Device Manager, then check if your keyboard if present
4. If this steps didn't work then you might need to replace your keyboard. ^_^
Hope this help you with your keyboard issue. Have a great day and thanks for using Fixya.
May 18, 2011 | Acer NSK8458AN Keyboard
None of the keys work on hp logo screen F10, f11. f9. esc system won't boot from hard drive or cd
are you using a usb keyboard? A lot of systems require a ps/2 (purple round connector) keyboard to access the bios settings and anything on the startup screen unless you have set usb on boot in the bios settings. I would try connecting a ps/2 keyboard and see if it helps.
May 06, 2011 | HEWLETT-PACKARD Pavilion Desktop with AMD...
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
