Question about IBM ThinkPad 600E 2645 Notebook
Unit will not boot from cd/dvd, drive test good.
Installed new HD (120GB) and the ubit will not boot from cd/dvd with the ibm recovery disc, it won't reconize it, so I can't install OS (98se). Have tested every component bot??? won't boot
  • icgajjar Sep 03, 2008
    I am to replace HD with new 120 GB, but don't understand how to start
    because i know that i'll be not able to ot Os using CD Rom.
    also I don't know that its going to support 129 gb
  • pkgatiso Sep 04, 2008
    my imb thinkpad 600e shows some errors of bios and windows xp. it does run at all but whn i try to install xp it doesnt boot from dvd rom. pkgatiso@yahoo.com
Try to boot with floppy with cd rom support!
Posted on Aug 03, 2008
    Genius:
  • 2,028 Answers
The main programing on the motherboard (bios) should recognize and read from the CD drive, If it doesn't then there is three possibilities as to the problem. 1- the bios have glitched, so, start by doing a bios flash. 2- the optical eye or the reader board in the CD drive has gone out, and the drive will need replaced, 3- there is a malfunction with the motherboard, and the board will need to be replaced. These three are the only possibilities and fixes for this problem.
Posted on Jul 26, 2008
IBM thinkcenter says no os after installing DVD writer
Did you install a SATA or an PATA (IDE) drive?
First check that the data cables are connected to both the hard drive and the motherboard. (I know that I've frequently had the cables come loose from the motherboard on my ThinkCentre 8433 when I work in the case.) Also check that the power cables are firmly connected.
Next make sure that you have no disc in the DVD writer. (Or enter the BIOS by pressing F1 (IIRC) repeatedly on start up. Make sure that the hard drive is the boot disc.) While in the BIOS, you can check if the hard drive is recognized by the motherboard. If you don't see the disc listed, recheck the data and power cables.
If the hard drive was working before you replaced the dvd drive, you may have changed the master/slave assignment on the drives (if they are both IDE). Remove the drives from the computer and check the jumpers. (These will depend on the manufacturer. Use either cable select or master/slave as needed) The boot drive should have the jumper set to master or cable select. In the case of cable select, the boot hard drive should be connected to the black connector. The slave drive goes to the grey connector.
If you connected a SATA drive, try swapping the SATA ports (SATA 0 or SATA1) that has the optical drive connected to it.
The next thing to try requires either the Windows install or upgrade disc for your version of the OS (including the Service Pack) or a third party partition manager/repair utility disc. You'll need to reset the boot order to boot from the optical drive (or press F12 on starting the computer). Use the Recovery Console (for the Windows disc) to find any existing OS installs on your hard drive and attempt to repair the master boot record or boot sector if it still exists on the drive. Please add a comment with your OS for specifics on using the Recovery Console. (I replaced my WinXP with Win7 and the methods are different.)
You may have been unlucky and had the hard drive fail while you were working in the computer. See if the recovery partition (F10 on boot) still works or use your system image (Rescue and Recovery DVDs) will restore your computer to the last backup. Try doing the restore to a new hard drive if the recovery discs don't work.
I hope this helps. Please add a comment with any comments that will help me give more specific assistance for your missing OS.
Aug 09, 2012 | IBM Computers & Internet
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
Just installed a new hdd 500gb on my acer 5100 and now it won't read the recovery disc. Plz help. Dwayne
is the hd formatted?
when the computer is booting, hit the f12 key. this gets you to the bootup sequence windows. highlight the cd/dvd drive as first startup. reboot w/the recovery disk in the drive. this should allow you to format the hd and then install th files on the recovery disk.
Dec 24, 2009 | Acer Aspire 5100-5022 Notebook
Vista Crashed does not recover (Can't install XP or 98SE either)
if you want to recover vista then download vista recovery disk here is the link
http://rapidshare.com/files/145731926/WVRD_www.warezspark.com.part1.rar
http://rapidshare.com/files/145698726/WVRD_www.warezspark.com.part2.rar
password : www.warezspark.com
burn the ISO disc and boot from cd rom and get it repair it automatically.
if you want to installed windows XP or 98;the reason why your hard disk could not be detected is your hard drive is SATA. disable any sata setting in your BIOS IDE configuration( if setting is not available then download SATA driver and Nlite ;make a bootable windows xp disc  with SATA driver pre installed .
this is solve your problem
here is the link for lastet SATA driver
http://download.cnet.com/SATA-Driver-Intel-Ver-7-0-0-1020-zip/3000-2122_4-162224.html
here si the link for lastest nlite software
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
regarding how to make a bootable cd with nlite with sata driver check out this link
http://www.windowsreference.com/free-utilities/nlite-slipstream-servicepackshotfixespatches-create-bootable-windows-cd/
let me know if it's helpful to you
Dec 09, 2009 | HP Pavilion dv6000z Notebook
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Ntldr error on ibm intellistation z pro w/ xp pro
During the XP install, you will be given the chance to set up partitions on the drive. Blow them all out. Completely. Then recreate the partition and let XP install. I expect this will solve the nt loader issue. If, however, it does not, then use the recovery approach below to get the required loader files onto your boot partition.
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "d." This letter may be different on your computer.
    copy d:\i386\ntldr c:\
    copy d:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Mar 04, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Unable to boot, I can't installed WIN98
NTLDR is NT Loader which indicates that the hard disk originally contains an NT OS such as Windows XP. The laptop not reading the installer is possibly a CD ROM or CD disc problem. Most (but not all) NT OS would be using an NTFS type of HD format. Windows 98SE would only read and install on a FAT(32).
What perhaps you can do is to remove the HD from the laptop and using an external 2.5 interface to USB connect it to a 2nd PC and re-partition that HD as well as format it to FAT32. You can also make that HD bootable (do a Google) and copy the entire CD installer of Windows 98SE to a folder inside that HD.
Once back to the laptop, it should boot to a C: prompt, go to the folder where the Win98SE installation/setup files are located and run setup.exe.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 06, 2008 | Compaq Armada E500 Notebook
How do I transfer files from Windows 98se to Vista on my new computer
If you have a CD/DVD writer, you can write the files to a CD-R. If this is not an option, take out the HDD from he Win 98se machine and install it in the vista machine, if you have room. you might need to disconnect your CD/DVD drive in your vista machine to free up the EIDE ribbon cable.
option 3:
Win 98se can do USB, but not very well. And drivers are hard to come by for usb flash drives. Vista/XP/ win 2000 can handle them without needing a driver disk. Therefore you will need a new OS for the win 98se machine. How about linux, it can handle usb flash drives very well. My advice use Ubuntu linux, you don't need to install it, just get a boot CD. it boots the OS from the CD, does not install or format anything. Use that OS to copy the necessary files to the flash drive. This option requires you to have a cd burner or access to one, so not really saving any time.
http://www.ubuntu.com/
You did not give ne a lot of information about your setup. Like do you have a cd/dvd burner, any usb ports, any spare HDD, any external media storage. Do you have any burning software like nero. So pick which option that is viable.
You can also take your computer to best buy and have them back up the data on a CD/DVD disc for a price. Best Buy is not the only shop that does this type of service, check in your area.
Feb 12, 2008 | Computers & Internet
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
191 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
