Question about Vacuums
Shopvac motor not working
The switch was by passed and wired directly to the motor and it won't operate at all.
  • jimrshaw Feb 04, 2009
    Why is it so difficult to find motor brushes for my Craftsman wet/dry shop vac?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
If you need the whole motor assembly you can get it from Sears at this website. www.searspartsdirect.com I just need a set of brushes for the motor
Posted on Feb 26, 2010
I've got the same problem. Sears wants $53 plus shipping for a replacement power assembly which is the price of a new vacuum of the same size. Where can I, and this poster, get just the motor?
Posted on Sep 16, 2008
    Genius:
  • 1,027 Answers
Then the motor brushes may be worn, or a winding is open circuit. Sears is pretty good at replacement parts, and they probably can supply just the motor assembly.
Posted on Jul 26, 2008
Shop vac fuse
Very rarely do vacuums have a fuse in them. You probably have a bad switch or possibly a bad motor.
Mar 29, 2014 | Shop-Vac Corporation Bulldog 8 Gallon...
Mod.#J150A shopvac won't turn on
These units are not high quality. There are problems with the motors and the switches, you can check these things or just get another one. If you get another one, get a different brand.
Feb 09, 2014 | Vacuums
Do you need a special filter for wet application
Yes. The following site shows the filters and which is used for what. Due to potential motor damage, I wouldn't use it without the proper filter.
http://www.shopvac.com/shopvac-accessories/Departments/Wet-Pickup.aspx
Jan 03, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Motor/Fan does not run. I have removed and taken the top of the canister plastic motor housing apart and tested for power. I have power through the cord to the switch and power from the switch to the two...
Sorry to read about your problem, I hope this helps you out.
Well you can order a new motor at shop vac, check out this link.
you dont have to remove to check the motor, just connect power to the motor leads
www.shopvac.com/support/
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Shop Vac QPMH450 Canister WetDry Vacuum
Shopvac 90L400 quit working (4 years old). Thought the switch was bad but not the problem. I read that there is a fuse link in the motor that frequently burns up. I tried to take motor apart but not sure...
by pass the switch and take power right to the motor leads.. that should tell you if the motor is ok.. have not seen fuse link on a vac motor.. graingers has new motors, but not inexpensive
Nov 30, 2009 | Vacuums
Explain how to re-wire 16gal craftsman shopvac,switch wires are- 2 orange wires, one white, one black and one green(grd wire), I pulled them off and don't where each wire goes.
Im not looking at a diagram of your machine.
Typically, in a switch circuit ... the green goes through; the white goes through; the black is broken by the switch.
The two orange wires you speak of ... those come from where? Are they from the motor? If yes, one connects to the white and one connects to the switch.
If I have misunderstood your question, please ask again.
a
Oct 05, 2009 | Vacuums
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Shop vac QPL625 on off switch stays on.
Contact Digi-Key 1-800-344-4539 or 218-681-6674 ask for part number EG1505-ND.
Cost is about $2.00 plus shipping.
See http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=EG1505-ND for part details.
You want a D.P.S.T (On/Off) mini-rocker switch.
Apr 16, 2008 | Vacuums
Vacuums Logo
203 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
