Question about D-Link DI 514 Wireless Router (DI-514)
Resetting DI-514 Hi... I just moved to a new apartment and got internet put in today. I tried connecting my wireless router but the set-up wizard will not come up and it will not work. So I tried to reset it to factory settings but it did not work. Please help!
  • Thomas Lim
    Thomas Lim May 11, 2010
    Please provide the following information so that I can give you detailed steps on this.
    1. Number of computers.
    2. Internet Provider. Type of connection cable or DSL also give me the IP that you get when your computer is connected to the modem directly.
    To check the IP.
    1. click start then run then type in CMD
    2. Type in IPCONFIG in the DOS window
    3. Look for IP address
  • 928 Answers
May i follow up
Posted on Aug 06, 2008
Hi, My Dlink 514 suddenly went down and lost connection to internet. I followed the usual procedure of resetting and connected back. But the problem is the SSID is "default" and saying...
This is common problem with your ISP maybe they are doing some maintenance, can you contact them please, and check with them to to refresh your net ports. After this do as you did before, connect to your problematic router, and everything should work charming ^^ :)
Thanks for using my services, please rate my solution, and really good luck :) Alex
Apr 13, 2011 | D-Link DI 514 Wireless Router (DI-514)
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I want to change my username and password..i have wi-fi connection.and my router is from d-link.
To reset your wireless router to the default, hit the the reset button
46e1c92.jpg Whenever you want to configure your network or the DI-514, you can access the Configuration Utility by opening the web-browser and typing in the IP Address of the DI-514. The DI-514 default IP Address 192.168.0.1
· Open the web browser
· Type in the IP Address of the Access Point
Type admin in the User Name field (lower case)
Leave the Password blank
Click OK
The Setup Wizard page is the first page that appears when logging into the web-based management interface. The Setup Wizard is a utility used to quickly configure the DI-514. It will guide you through four quick and basic steps to help you connect to your ISP. You will be connected to your ISP (Internet Service Provider) and have Internet access within minutes.
If you need the entire user manual, follow this link and choose Product Manual. You can download a zip file with the manual in it.
http://www.dlink.com/products/?tab=3&pid=DI-514&rev=DI-514
Mar 12, 2010 | D-Link DI 514 Wireless Router (DI-514)
I can not get D-Link wizard
Hi, have you upgraded it´s firmware or anyting similar? Try resetting the router with a pen. It should start up after some time. If not, let me know.
Oct 06, 2009 | D-Link DI 514 Wireless Router (DI-514)
Ran the setup wizard for the d link di 514 but still cant connect to internet
Do you have Internet connection before you installed the Dlink router? Do you have cable or DSL? If you have DSL make sure you have the username and password from your Internet service provider because you need to enter those information when you run the set up wizard. You need to connect your computer to the LAN port of the router. Turn off computer and router, turn on router first then turn on the computer. Run the set up wizard again.
http://technicalsupport.blog.friendster.com
Sep 18, 2009 | D-Link DI 514 Wireless Router (DI-514)
Current dlink basic want to use dling DI 514
If you want to use your former router, you just have to connect the previous router in between your modem and computer. Try turning off all the devices (modem, router and computer) for 2 minutes. Then turn on the modem first, wait for the lights to be stable then turn on the router. When the router lights are okay that is the time that you can turn on the computer and check the internet connection.
If the Internet connection still has not come back, you will have to reconfigure it for Comcast connection. You can try using the setup CD or access the setup wizard using 192.168.0.1. User name is admin and leave the password empty then run the wizard.
May 05, 2008 | D-Link DI 514 Wireless Router (DI-514)
Connection Issue ~ D-Link DI 514
Connect to your router, then on the computer click start/run, type CMD at the >, type ipconfig /release, then ipconfig /renew this will reset all ip address from your computer through your router to your modem. this should fix the problem. BPCS
Dec 30, 2007 | D-Link DI 514 Wireless Router (DI-514)
Connecting 2 computer thru DI-514
Well I believe wat ya need to do is simply obtain a NEW "Account" with NEW Logon & Password with a NEW Internet Service Provider. Then you set up the modem to connect to the new ISP, at the NEW ISP's address, with the NEW Password & Logon. When you got the modem ya should have got a "Setup" CD that should walk ya thru the connection routine... Below is a link for a "Users Manual" that should help you get connected. ftp://ftp.dlink.de/di/di-514/documentation/DI-514_qig_en_Quick-Install.pdf
Aug 15, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI 514 Wireless Router (DI-514) Logo
80 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
