Question about Samsung LN-S4692D 46 in. LCD HDTV
LN-S4692D 46 in. HDTV T-Con Board
Hi
Can anyone guide me (pic, label, etc.) to the fuse on this t-con board?
I've replaced the t-con board and now want to repair the blown fuse in the old one. I have no idea how to find it. A tech did tell me the fuse was blown but I didn't look ar where it was. I just ordered a board and replaced it. I feel there is very excessive heat coming out of the back of this series TV (I didn't like the amount of heat from). and couldn't that heat be the culprit behind the mass failures of this this totally enclosed board?
thank you for any info.
Sincerely,
John Sullivan
    Genius:
  • Samsung Master
  • 1,689 Answers
This answer is generic:
Most of the time they use fuse resistors. Sometime there a number of them. They are not all the same. This is not a simple fuse. It is a resistor combined with a fuse. You would need the service manual to properly identify the fuse resistor and have its spec. You would then have to order the correct one from a parts distributor. If it cannot be replaced generically, the original would have to be ordered from the manufacture.
In any case, if there is a blown fuse on a power supply board you can be sure that there are failed components that are most likely shorted. This would mean that the board would have to be troubleshooted to find and replace the defective parts.
Most of the circuit areas and the boards in these sets are not supported to be serviced at the component level. They change the defective boards as in the same process as servicing computers.
As for the heat problem, if you can find someone who is technically very competent, maybe he can custom install a fan for the area that is getting heated. It should be possible to find a 12 volt source from the main power supply to run a small fan to assist for extra cooling.
If you have your set in a cabinet, or if it is wall mounted it may run hotter. We found that sets that are wall mounted tend to fail more often because the heat can reflect off of the wall back in to the set. Cabinets tend to not allow the heat to dissipate as well as out in the open.
Jerry G.
Posted on Jul 26, 2008
Hi, i have a fairly new samsung 46" tv with sound but no picture
Please check in dark room condition if you can see the light come up in the background of the tv LCD. If you can see light it would be a T-Con board or main board problem. I think those tv had some issues with the T-con board.
Search results for ln s4692d
Feb 24, 2015 | Samsung LN-S4692D 46 in. LCD HDTV
Sound with no picture
More than likely it is the T-CON board that went bad in your television set. Fairly easy to replace yourself you can buy online on ebay. Search T.V. model # followed by T-CON and one should be available. There are many youtube videos on how to replace step by step. GOODLUCK!
Jan 26, 2013 | Samsung LN-S4692D 46 in. LCD HDTV
What are the parts mounted on top of the LCD Panel? They connect to the LCD Panel on the output side and are connected to the T Con Board on the Input side. I believe the are like Buffer Boards on a...
There is T.con board use as a output for LCD panel.Input come from Main board. One power supply board and invertor board for back light.Thats all have in side LCD TV.
Nov 04, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Got a new T-con but no luck
is your back light constantly on when you are not changing channels.if so replace the main board. can you see a menu if you hit the menu button ? that is generated by your main board..... replacing the t-con will only correct vertical lines in the pic.
Feb 27, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Pico fuse
It's on the T-con board itself at location Cp1 which you will find printed on the board itself.. The fuse is a tiny s/m (surface mount fuse but you can use a pico fuse of same value. According to schematics it's a 1.5a fuse. Simply solder one across the s/m fuse and if it opens then change the board. Samsung p/n# Bn81-01286a
To test the fuse use a VU meter set to continuity.
Pico fuses are readily available at almost any electronics supply outlet. I get mine from ACME Sales in Florida (least expensive) but even your local Radio Shack might sell them...
Bill
Sep 04, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Hi I have the same problem with Samsung LN-S4692D, which phone number did u call?
you need a T-con board, if there is no backlights at all it could be the power supply
Sep 03, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LNS 4692 lcd tv t-con board
The fuse is located just upper right to the connector that attaches to the main board. This is a SMD pico fuse that is rated for 3 A @ 32 V DC that protects the Vin bus. Replacing the fuse may not fix the problem as it has most probably opened because of failure of another component.
Jul 26, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
T-con board
small board at the top of the lcd panel under the shield
Jun 16, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung t-COn board
the T-con board is located on the top of the lcd panel under a shield
Jun 13, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-S4692D 46 in. LCD HDTV Logo
488 people viewed this question
Jerry Greenberg
Jerry Greenberg
