Question about HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop
Connecting FAX on HP OfficeJet Pro L7680
I can't find a phone connection on the back of the computer. Do I need a special DSL connector and if so how to connect to standard phone connection?
  • HP Master
  • 4,338 Answers
If you don't see a phone jack on the back of the computer, it means that you do not have a dial-up modem in the unit.
A DSL line is installed with the cable modem supplied by the DSL company, ie: Bellsouth, AT&T. It connects to your computer via the network port.
The DSL provider supplies the modem and the filters that you need to install on your phone outlets.
Hope this helps.
If it does, please rate it.
If not, I can give you further assistance.
Joe
Posted on Nov 21, 2008
I have tried everything to get my printer to receive faxes but to no avail. Have reinstalled drivers, set distinctive rings over and over again, unplugged and replugged in everything. I'm at my wits...
If you are using a DSL Internet connection you must put a DSL filter on the phone line going to the printer. Without the filter, all the printer is hearing is internet noise..
Apr 15, 2011 | HP Officejet Pro L7680 All-In-One Printer
I have an HP L7680 all in one printer/fax/copier. It prints just fine, it copies just fine, but INCOMING faxes do not print the entire page. What do I need to do?
first check all the connection to the printer check the phone line connected firmly on the printer then check for dial tone try to dial from the fax in the printer to any other number then return the call to the fax
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
I connect to my HP Officejet Pro L7680 All-in-One Printer the wrong power supply and now dnt swicht on, in the back lights goes green but nothing happens. I have electronics knowledge to fix it but maybe i...
Hi live_intheda
I 'm not familiar with the device but isn't it just a question of replacing a burned fuse ?
Is the power transfo inside the unit or is it external together with the connecting power cable ?
Regards ,
fanaudi .
Mar 13, 2011 | HP Officejet Pro L7680 All-In-One Printer
We have the L 7680. Last week we changed from ATT dsl line with filter to ATT Uverse. They installed. With the change, our fax stopped working in/out. It reads as No Answer from outbound attempts and...
The Uverse service appears to be all digital - so any voice/phone channels are going to be VOIP....not real analog lines as you had before. So, you need to connect the HP fax to a phone line service. Did ATT provide you a phone number? (or perhaps 2 phone numbers) Then the fax should be connected to that line. If you are unsure, then connect a phone to the provided line and listen for dial tone. If you are connecting a fax to a VOIP line then a good suggestion is to drop the fax speed to 9600....this will provide more reliable connections. Hope this helps
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 All-in-One will not scan or fax
connect the phone line in printer and set the parameter like auto answer and sending and receving mode also install the scanner driver .just reinstall the printer driver it will installl the missing components.
Dec 18, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 shows "Phone off hook"
scroll through the menu of the machine and come to the fax settings and then and chck if the line in use is line 1 or not,the DRP is set properly according to your telephone service provider,you have the phone line connected to line 1 port of the machine,you are not using a digital line for the fax machine,if you have a TAM then set the printer to picj\k up fax calls at two more rings than your telephone.
if you want a technician to do the entire troubleshooting for you.You may get in touch with one of the techbuddies,they offer free technical support for such issues.
you may get them at http://tinyurl.com/m7ghqz
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
I want to fax using my HP OfficeJet Pro L7780. I
Click here for online manual and setup guides.
Clcik here to view DSL phone line setup instructions
& here for the general fax menu
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Fax on Officejet 4315
Here, you will find information connecting the OfficeJet to different phone system configurations. Its sounds like it is being connected to a DSL connection so I would refer to that section first.
Also, here is information on "Phone Off Hook" issue.
If none of these options help, here are some additional options that may help.
Nov 26, 2008 | HP Officejet 4315 All-in-One Printer
Can't fax in or out with my L7680
386
387
388
389
390
391
392
393
394
395 The machines were unable to complete the handshake.
*Try to send the fax at a time when telephone line conditions have improved
Aug 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop Logo
100 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
