I have power to the television. i know this because the power button is lit. however when i push the power button, it does not turn on. will not turn on with remote either.
Red led indicating "off" is lit, push "on" button and red led goes out, no green led.
Al, Power supply board instructions. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
i used code 0134. push and hold set up button till lit then hold tv button till it flashes then put in code 0134. now push power button on remote. tv should turn off. i just had same problem. i also use a ge universal remote. hope that helps.
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
What kind of remote is it? if it is rca you can push the device your going to program it to such as the tv then hold the power button until it stays lit oh, by the way the tv should be on while you do this,now that the power button is lit keep pushing it until the tv turns off as soon as it turns off you push the stop button on the remote like you were going to stop a dvd.Now press power again and your tv should turn on,repeat these steps for all your other devices and your done with no codes,hope you have an rca remote and if you dont maybe they have this no code feature in other brands,good luck
My dear friend if your remote control got the code search button try with this.
Push and hold code search button until the led stand lit,now release him push and release the tv button the you need to push and release the power button until the tv set turns off push and release the button set and the code get in the memory of the remote.
You need to turn the tv manually.
Good luck
When you push Power Button on remote, TV goes to Standby state i.e its power light (LED) lit but no picture / no sound. Power button on remote has symbol looks like.. ( ! )
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
