Question about Canon PIXMA MP160 All-In-One InkJet Printer
Scan gear error code:22500
I connected scanner to my computer.but when I try to scan the document it displays the scan gera error "an error has occured.turn off the device and turn back on.scanner driver will be closed.code 22500...please help
  • 2 more comments
  • knight_lv Dec 22, 2008
    i connected scanner to my computer.but when I try to scan the document it displays the scan gera error "an error has occured.turn off the device and turn back on.scanner driver will be closed.code 22500...please help
  • Anonymous Mar 15, 2014
    i cant scan its show error and code 5,202,54
  • Anonymous Mar 23, 2014
    i want to scan a document from the glass of the scanner and I don't know how. please help me
  • Anonymous Mar 27, 2014
    try to scan keep getting error while scanning occurred
Check Cannon support site, it has all solutions. Good Luck
Posted on Feb 19, 2009
Hi my canon pixma mp160 is showing scan gear error coad 22500
Mar 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Prints but cannot scan
Check first if you can try to make a copy as standalone (without the help of the computer)
If that works it means scan feature is working fine and printer is not the issue.
then you might look to troubleshoot issues with software side
try making scan from MS Paint
click File then click from scanner or camera
if that works then the driver is not the problem but it could be HP software
How to scan
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=57734&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=90792
Slow / No response from scanner
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=38085&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=90792
The Scan Button on the Printer Does Not Function When the Product is Connected to a Windows Vista Computer on a Network
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809939&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=90792
A 'No Scan Options' or 'Scan settings are not set' Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02450835&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=90792
Error Messages Display When Trying to Scan with the HP All-in-One Product
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00679&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=90792
A 'Scanner Failure' Error Message Displays on the HP All-in-One Product Control Panel
Hope I help you a bit.
You can also send me questions on my
personal email - christian4122@yahoo
Your's Truly,
Christian from HP
Feb 11, 2011 | HP Officejet 4110 All-In-One InkJet...
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Scanner error code
This generally indicates a driver error.
Download and run the Scan Diagnostic utility
  1. Download the HP Scan Diagnostic utility .
  2. When prompted, select Open or Run to start the download and run the installer, and then follow the on-screen instructions.
  3. Try the scan again.
The Scan Diagnostic utility checks the physical connection between the device and the computer and address the issues with the following components of the scanning software:
  • PML (Printer Management Language)
  • Yellow DOT4 entries
  • Scan Folder
  • Registry Mismatch
  • HP Digital Imaging Monitor
  • Multiple HP Digital Imaging Monitors
If an error condition is identified with any of these items, a red X ( ) appears next to the item. If there is no error condition, a green check mark ( ) is displayed next to the item. The utility is equipped with a Fix button to correct the error conditions.
Run the Unexpected Internal Error and Communications Failure patch
  1. Download the patch for HP Image zone/photo, imaging unexpected internal error and communications failure.
  2. Double-click the patch to install it on the computer.
Try scanning without HP Imaging software
Try to scan with the built-in feature of Windows operating system called Windows Image Acquisition (WIA). To perform a WIA scan, follow these steps.
  1. Make sure the product is turned on.
  2. Click Start , and then click Control Panel .
  3. Click Printers and Other hardware , and then click Scanners and Cameras .
  4. Look for an icon for the product.
    • If there is not an icon for the product, click here to uninstall and reinstall the software .
    • If there is an icon for the product, click the icon, and then follow the on-screen instructions to scan images or documents to the computer.
Sep 21, 2009 | HP J3680 Officejet All In One Printer
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Error messages appear when scanning from glass to macbook.
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error code 08
Unplug your scanner and switch off your PC. Check the USB connection is secure on scanner and pc. Wait for at least one minute, then switch both back on. Your display should go back to 01 now.
Sep 04, 2008 | HP ScanJet 7650 Flatbed Scanner
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Apr 14, 2007 | Acer Scan to Web 3300U Flatbed Scanner
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
2,303 people viewed this question
old marine
old marine
