Question about Oster 5838 ExpressBake Bread Maker
Oster 2 lb. EXPRESSBAKE: clicking sound while the kneading
My 2 lb. EXPRESSBAKE Breadmaker is making clicking sounds at every turn of the kneading blade. Everything else seems to be OK. Clicking started out of the blue and does not go away. What can I do?
  • Anonymous Nov 02, 2008
    Brand new out of the box, seated everything as necessary, unit clicks but does not turn motor connection to paddle. No spin at all going on.
  • olji Dec 14, 2008
    I checked the band, it is fine. Thanks for trying.
I JUST GOT ONE ON NOV 12 TH AS A BIRTHDAY PRESENT OPENED IT TODAY - SAME PROBLEM- CALLED 1800 NUMBER FROM MANUAL - THEY ARE SENDING ME A BRAND NEW ONE FREE OF CHARGE.
Posted on Nov 26, 2008
Most likely you need a new band I believe you can order one for $12.95 You need to remove the bottom panel and check the band first.
Posted on Oct 26, 2008
Kneading blade comes off during breadmaking process
Yes, if the blade come off then your bread is not going to mix and knead properly. The blades on all makers are designed to slip on and off though so you can remove them for cleaning etc. Be sure you are pushing the paddle all the way on. If it still comes off when mixing that would be very odd as the weight of the dough ball itself helps keep paddles on. I have owned dozens of machines by different manufacturers and never had a paddle come off in process.
Jan 01, 2013 | Sunbeam Oster CKSTBRTW20 Bread Maker -...
MY OSTER 5838 EXPRESSBAKE BREADMAKER MAJES HORRIBLE GRINDING SOUNDS WHEN MIXING
You may have a bearing problem causing the grinding noise or the motor stator is rubbing on the housing
Jan 01, 2012 | Oster 5838 ExpressBake Bread Maker
I have a older model Oster bread maker I cant find the model. I brought it from Salvation Army and I need a manuel
Oster manuals are not the easiest to find; here are three; hope one is is for a model similar to yours. If you can find your model number on the botton or back might be able to assist further.
Thank you for using FixYa!
CKSTBRTW20 - Oster® 2lb. Expressbake® Bread Maker
http://www.oster.com/manuals/MANUALS/CKSTBRTW20_43_33506787.PDF
5838 - Oster® 58-Minute Expressbake® Breadmaker
http://www.oster.com/manuals/MANUALS/005838-000-000_ENGLISH.PDF
Deluxe 2-Pound Bread & Dough Maker
http://kitchen.manualsonline.com/manuals/mfg/oster/deluxe_2pound_bread_dough_maker_p_n_101017.html?idRes=2148332
Sep 14, 2011 | Oster 5838 ExpressBake Bread Maker
My breadmaker makes a clicking sound when started but does not knead.
That is normal. It is warming up and that is the clicking sound you hear. It should start after a few minutes (less than 30 minutes is normal).
Apr 16, 2011 | Cuisinart CBK-200 Bread Maker
I have a Welbilt ABM 4000. When I try to use it on any setting, the timing counts down but the machine makes a clicking sound and the paddle does not move.
If the ambient temp is below ideal some machines will heat up a little first before kneading. The clicking sound is the sound that all the machines make as they start to heat up. As long as it starts kneading within 15-20 minutes everything is OK.
Nov 21, 2010 | Welbilt ABM3500 Bread Maker
5838 ExpressBake Bread Maker: I have the Oster breadmaker 5815 and need the manu...
you will get any Oster breadmaker manual with the manualfox search engine. Check results here:
http://manualfox.com/link/oster.htm
May 17, 2010 | Oster 5838 ExpressBake Bread Maker
Paddle sticking in bread when baked bread is removed. Oster Breadmaker 5838
This is a common problem. The solution is to take the paddle out of the machine after the last kneading cycle and before final rise/bake. You may want to take the pan out of the machine to remove the paddle to be safe...unless your machine has a pause cycle. Hank
May 18, 2010 | Oster 5838 ExpressBake Bread Maker
Oster 5838 ExpressBake Bread Maker Logo
256 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
