Question about Lands Phones
2 Telephone lines and one phone jack
I live in Japan. This means that I have two phones. One is my vonage phone that goes thru the internet and into a regular phone. The other is a DSN style landline for the military base. I currently just have two regular corded phones hooked up to the individule lines. I want to upgrade to a cordless phone, but I only want to have to buy one for both lines. I thought of getting a two line phone, but it seems that even two line phones only have one entrace jack. How would I hook both phone lines up to the one phone?
    Scholar:
  • 108 Answers
Most of the Cordless 2 line phone BASE UNITS have the connections on the back for line1/line2 or seperate line 1 and line 2 connection. If you have the type of phone with the line1/line2 jack you have to be sure that both lines are on the same wall jack, otherwise make sure the phone you purchase has seperate line jacks and you will have two phone cords going to the base unit.
Posted on Jul 27, 2008
Vonage and ADT
Does the ADT system use a phone line to call into a local police department or security team? What do you mean by parallel phone system?
Dec 04, 2011 | Home Security
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Tip
How to connect your VOIP phone service (IE Vonage, MagicJack, Via Talk) to...
Are you tired of being tied down to your computer area to use your VOIP phone service (IE Vonage, MagicJack, Via Talk or ITP)? Here is a way to make your existing home phone jacks work with your VOIP.
***** DO NOT USE THIS TIP IF YOU HAVE DSL (FROM THE PHONE COMPANY) FOR YOUR INTERNET SERVICE PROVIDER OR IF YOU ARE IN AN APARTMENT BUILDING*****
Items you will need-
  1. An existing home telephone jack near your VOIP service modem.
  2. A screwdriver
  3. A telephone cord long enough to reach from the VOIP service jack to the existing phone jack.
COMPLETE THESE DIRECTIONS EXACTLY AND IN ORDER OTHERWISE DAMAGE COULD RESULT TO YOUR VOIP MODEM.
NOTE THAT EACH HOME IS SLIGHTLY DIFFERENT AND MAY HAVE NON-STANDARD WIRING SITUATIONS OR HAZARDS UNFORESEEABLE SO THIS TIP IS TO BE DONE AT YOUR OWN RISK AND YOU WILL BE RESPONSIBLE FOR ANY CONSEQUENCES THAT ARISE FROM WORKING ON YOUR OWN HOUSE SUCH AS IF YOU DAMAGE ANYTHING OR GET SHOCKED OR FRY YOUR VOIP MODEM AND BURN DOWN YOUR HOUSE IT'S ALL ON YOU....
So hopefully I haven't scared you off from trying this tip since it is fairly simple to do but complements of lawsuit happy America I had to cover the disclaimers....
Let's get started...
First thing you need to do is to locate the main telephone junction box to your home usually located outside near the power meter. Here are some pics of some standard used boxes.5124c69.jpg
There is a screw keeping the customer access door closed. Loosen this screw and open the access door to expose the home wiring. Note: this screw does not usually come completely out. To set you at ease, yes it is completely legal for you to access this portion of the box. The portion that you are not supposed to access is restricted by a security bolt and can not be opened with a normal screwdriver.
Once you have the access door open there are two types of commonly used connections.
  1. The most common is one similar to this picture. Disconnect the lines attached to the test jacks.
    If you have more than one line here then loosen the screw terminals one at a time and place the wires from the other lines to the same terminals on Line 1 so all jacks in the home should be available.
    Note: there may be a cover over where the screw terminals are for where LINE 1or 2 are, simply pull the cover toward you to expose the terminals.
2) The second style is very similar to the first but the area where the screw terminals are has a plastic rectangular bar about 2 inches long and 1 inch wide with telephone lines attached to it (often times Red and Green or Blue and White/Blue). If you have this style of connection push the side of the bar closest to the center of the box and then pull outwards and to the right this should expose the "Test Jack". Once the bar has been extended twist it 1/4 turn counterclockwise to remove it from its mounting bar. Use caution not to disconnect the phone wires attached to the bar.
Almost there and now the hardest part should be done.
Now return to where the VOIP modem is located and remove the telephone cable for the phone that was being used for your VOIP service.
Connect the new phone cord to the same outlet that the phone was connected to on the VOIP modem and then connect the other end to the home phone jack.
If you still want to connect a phone to the jack you are connecting to here then a simple telephone line splitter plugged into the jack will fix that.
Now try to connect a phone to any of the phone jacks in your home and you should have dial tone. Note that most phone service is made to comfortably handle 4 phones that connect to a phone jack.
on Jan 16, 2010 | Lands Phones
Phone line juction connection?
FIrst of all, you don't change the line from the pedestal to the trailer. It's not your cable and it doesn't matter. Dial tone comes in on that cable and it works just fine. It's also the feed to your DSL modem, based on high frequency and not data.
If you're trying to feed different dial tone to 4 phone jacks, you need to find a way to unsplice the cables. In truth, all you have to do is find the main feed from outside, wire it to the DSL modem, and backfeed the 3 other cables with the dial tone from the Vonage or whatever ATA. This backfeed will run on any cable and does not need to be Cat 5e.
If you're trying to run network cables, then you need to run a new cable and connect it to a router or switch at some central location. Those cables need to be 5e.
Carl
Jan 08, 2010 | Computers & Internet
I just Bought the HP Officejet All-in-one J4540 Printer. I am also using Vonage as my phone source. I have high speed broad band internet cable. How must my phone jack hook ups be configured to send and...
Since a fax works over an analog telephome signal this is no different when you hook up a phone to your vonage. I believe you hook up a regular telephone to your vonage router via a telephone jack in the back of it. If so plug the fax machine into it via a splitter
Nov 25, 2009 | Office Equipment & Supplies
One number that will never go through
could be this number is a number to one of the internet phone companies. The small town I live in, the main Telephone provider wouldn't let vonage phones call phones on their exchanges. If you ask them they say it is a vonage problem and if you ask vonage they say it is the local phone company problem. You might also have to dial the area code or a 1 before the number so it will send.
Good luck solving your problem
Dec 15, 2008 | Lexmark X4270 All-In-One InkJet Printer
My in-laws have vonage telephone service with comcast internet, before they just had at&t with no problems. Now when they are having a telephone conversation the connection seems to cut in and out and...
With choppy audio and one-way audio, either party on the call hears the audio breaking up, or no audio at all. Dropped audio is when a call is in session and both parties are unable to hear each other.
  • From your Vonage account, there is a feature called the bandwidth saver. This feature controls the amount of bandwidth used for a phone call. Try adjusting the bandwidth saver to either medium or normal. After you adjust your settings, test and see if there is a difference in the audio quality. Please note that when you change bandwidth saver it could take a few minutes for the device to reboot and take the changes. From your Vonage account, there is a feature called the bandwidth saver. This feature controls the amount of bandwidth used for a phone call. Try adjusting the bandwidth saver to either medium or normal. After you adjust your settings, test and see if there is a difference in the audio quality. Please note that when you change bandwidth saver it could take a few minutes for the device to reboot and take the changes.
  • Reboot all of your devices (Vonage device, any routers and cable / DSL modems). How Do I Restart My Phone Adapter and Network Devices?
  • Ensure that your Vonage device is at least four feet away from any other device.
  • Ensure your Vonage device is in a well ventilated area to keep from overheating.
  • Ensure no file sharing, P2P applications, or large downloads are running while you are using the phone. These activities can use up most of your bandwidth, leaving little left for your calls.
  • Connect your Vonage device directly to your cable / DSL modem, if it is not already. If this helps the audio quality, then the problem is occurring between the Vonage device and modem.
  • If your Vonage device connects to another router and not directly to your cable / DSL modem, try disabling any firewalls or SPI (Stateful Packet Inspection) on that router. Click here to learn about firewalls and SPI.
  • If you wish not to disable your firewall, then you can port forward the Vonage traffic to the adapter. Click here to learn about port forwarding.
Wireless Routers and Cordless phones — If you have a wireless router and a cordless phone:
  • Ensure all wireless devices and cordless phone bases are at least four feet away from each other.
Home wiring — If you are using home wiring:
  • Ensure the land line has been disconnected in the Demarc box. Ensure the land line has been disconnected in the Demarc box.
  • Ensure there are no more than five phones connected through the house wiring. The signal fades as more phones are connected to house wiring.
  • Test with one phone directly connected to your Vonage device. If this fixes the issue, there may be a problem with your house wiring.
If you have made it through this checklist and you are still experiencing an audio problem, our first class customer service is available to assist you. Please have handy your account ID, phone number, name of your internet service provider (ISP), and model numbers for your Vonage device and any other devices in your network.
Dec 03, 2008 | Vtech mi6896 Trio Cordless Phone
Phillips faxjet connecting to vonage telephone service
Fax machines are ANALOG devices. Vonage is a DIGITAL phone system.
Oct 22, 2008 | Philips FaxJet 375 Plain Paper Inkjet
Hi, I switched to Vonage for phone service thru my hi-speed internet which is "over-air" thru csinet. We live in a rural area so this is our only hi speed internet option. Now my tivo fails to...
I have lots of suggestions, but you won't like them.
Somewhere in the fine print, it should have told you that modems, faxes, and alarm systems do not like VoIP.
Your phone company probably has lifeline service for minimal money......Do you get where this is going?
I know you'll ask how come one works and one doesn't, so before we go down that road, check with TiVo and see if you can change modem speeds. Or better yet, call them and tell them your receiver doesn't behave on Vonage lines.
They may have a trick 300 baud setting solution.
Carl
Sep 04, 2008 | Lands Phones
Lands Phones Logo
149 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
