There is no conductivity or connection between PC wireless card and the router.
    Champion:
  • 245 Answers
Did you instal correct drivers for wireless device ?
Go to manufacturers website and download and install correct drivers, when done restart computer... When back in windows if done properly you will be notified of a new network found.
Posted on Apr 01, 2016
4 Suggested Answers
kigwa2008
  • 68 Answers
SOURCE: keep losing my wireless connection
are your router is configured???
Posted on Jul 24, 2008
SOURCE: Can`t get wireless router to
  1. Go to "Network Connection"
  2. Click Right "Wireless Network Connection" Go "Properties"
  3. Click at Internet Protocol(TCP/IP) and click "Properties"
  4. At General bar,. Click on Obtain an IP address automatically and Obtain DNS server address automatically and Alternate Configuration bars, click Automatic private IP address
  5. After all of this click "OK" and "Close"
  6. wait for 30 second and try to connect again
Posted on Nov 10, 2008
yboyandrei
  • 828 Answers
SOURCE: Can i use Bluetooth USB Adapter to connect PC to wireless router?
Bluetooth is not capable of connecting device such wireless router, only is to allow connect from Bluetooth to Bluetooth connection, but Wireless Router can detect such USB Devices which called USB Wireless LAN. You have to buy it to connect 100% on your Wireless Router. Good luck!
Posted on Aug 03, 2009
My HP Probook 4720S has a very wierd problem. The wireless card seems to be working properly, and the drivers are up to date.However it cannot detect the wi-fi in my office.Other laptops are connected so...
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
If the other laptops are connecting to the wireless router, then look at the wireless card configuration in these laptops and apply the same settings to your HP Probook wireless card.
Sep 05, 2011 | HEWLETT-PACKARD HP ProBook 4720s 173...
Tip
How to setup a Wireless Network
1. <b>Connect Your Wireless Router</b> <br /><b>a.</b> Power off your cable modem and your wired PC.<br /><b>b.</b> Unplug the Ethernet cable from your cable/DSL modem and plug it into one of the LAN ports on the back of the wireless router. Leave other end of the cable connected to your PC.<br /><b>c.</b> Connect another Ethernet cable between your modem's Ethernet port and the wireless router's WAN port. (The WAN port should be separate from the other grouped LAN ports.)<br /><b>d.</b> Power on the modem and watch for the status lights to indicate that it's connected to your Internet service. This may take a minute or so.<br /><b>e.</b> Plug in the router. The status lights will blink as it runs through its diagnostics; this may also take a minute or so.<br /><b>f.</b> Start up your wired PC.<br />2. <b>Configure your Wireless Router</b><br /><b>a.</b> Refer to the router's quick-start guide, launch Internet Explorer, and type in the address indicated in the guide.<br /><b>b.</b> Follow the on-screen setup wizard, which will guide you through the process step by step.<br /><b>c.</b> Enable your router's security functions. This is very important if you don't want other people attaching to your wireless signal. The options will be WEP and WPA. Both will ask you to enter a key. Depending on the router's manufacturer, you may have to go into Advanced Settings to accomplish this step.<br /><b>d.</b> Change the default administrator's password, Almost all hackers know them.<br /><b>e.</b> Change the SSID-the name of your wireless network. Again, hackers know many of the default SSIDs and can use them to hack your network.<br />3. <b>Install a Wireless PCI Card in a Desktop PC</b> <br /><b>a.</b> Refer to the card manufacturer's quick-start guide. If necessary, run the software installation program.<br /><b>b.</b> Power down the PC.<br /><b>c.</b> Remove the cover.<br /><b>d.</b> Find an available PCI slot and remove the slot cover from the back of the PC.<br /><b>e.</b> Carefully insert the antenna through the open slot in the back of the PC, carefully push the card in the slot, and secure it. Replace the cover. <br /><b>f.</b> Start up the PC. It should recognize and install the new PCI card.<br /><b>g.</b> Go to the Control Panel, select Network connections, select Wireless Networking connection. Click on Properties button. Click on Wireless Networking tab. Select the wireless networking name (see step 2e). Click on Configure button. Configure your security settings to match the ones on your wireless router.<br />4. <b>Install a Wireless PC Card in a Notebook PC</b> <br />Many notebooks have built-in wireless cards. However, If yours doesn't, you can install either a USB wireless adapter or a wireless PC card just follow these instructions.<br /><b>a.</b> Refer to the card manufacturer's quick-start guide. If necessary, run the software installation program.<br /><b>b.</b> Power down the PC.<br /><b>c.</b> Plug your USB wireless Adapter or wireless PC Card into an available slot on the side of your notebook.<br /><b>d</b>. Start up the PC. It should recognize and install the new PCI card.<br /><b>e</b>. Go to the Control Panel, select Network connections, select Wireless Networking connection. Click on Properties button. Click on Wireless Networking tab. Select the wireless networking name (see step 2e). Click on Configure button. Configure your security settings to match the ones on your wireless router. well, thats pretty much it. Hope this is helpful to all you home networkers.<br />
on Jul 11, 2011 | Computers & Internet
Can I hoop up a wireless router to this computer
You can hook up any computer/laptop to a wireless router via LAN cable or by wireless connection.
For a wireless connection each computer/laptop needs a wireless card and the wireless card driver installed and the wireless card needs to be configured with the router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Apr 16, 2011 | Compaq Presario CQ2009F PC Desktop
I hooked up wireless router for computer.....one laptop and an ipod work off the network,but i have another laptop that see's the network but does not connect.......the same laptop will connect to anyother...
The wireless card in this other laptop needs to be configured with this router's wireless settings. It is using the other wireless router's settings and therefore cannot connect to this wireless router..
Most wireless cards in laptops will allow you to setup different Profiles for different router's wireless settings. This will allow the laptop to connect to the different wireless routers by selecting the Profile for the wireless router you want to use.
I suggest you name the Profile by location which will make it easy to identify the correct wireless router.
Jan 04, 2010 | Dell Latitude D610 Intel Pentium M 1.6GHz...
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Afriend gave me a Netgear Rangemax wireless router I don't have the instillation cd and I've never installed one could you help? I'm connected to qwest broadband and I have a Dell pc. My son just got the...
If you are connecting to the wireless router using LAN cables only then you can ignore the wireless setup part.
To configure Netgear wireless router and the wireless cards in the laptop and PC follow these steps : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL : -
http://192.168.0.1
3. Enter the router setup, login and password : -
Login = admin
PW = password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 18, 2009 | NetGear RangeMax WPN824 Wireless Router...
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Jan 16, 2009 | Dell Inspiron 1200 Notebook
Need Ethernet port on PC
If you have a wireless router then the ethernet cable will go between the modem and the router. Then you need a wireless LAN card to connect the PC to the router
What model router and modem do you have?
PC wireless card
Jul 03, 2008 | D-Link DFE-530TX+ Fast Ethernet PCI...
Emachine model t3302 ethernet card
This is how the wireless world works. You buy a wireless router with a four port switch. Your DSL or cable connects to that. A cable called a Rj45 connects the DSL or cable to the back of the wireless router. You also buy a wireless network card for your PC. After running the software for the router & the wireless nic card including setting up a home network through windows your daughter will be able to connect that computer to your network from any room in the house. Below is a link to a wireless router:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005578
You can connect up to four computers to the wirless router. A computer that does not connect to the router by a Rj45 must use a wireless network card. Linksys WMP54G Wireless-G PCI Adapter Retail: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=252286
As you will see there is a big differance between a NIC card & a wireless card.
Jan 01, 2008 | E-Machines eMachines Desktop PC
Wpn 824 wireless issues.
if you have set up the wireless connection and enable it in the router, i assume you have disconnected the wired RJ45 cable to the pc, if not do so, as the pc's ip address is still being sent to the wired adapter and needs to be giving the wireless adapter an ip address itself as you cannot have two. Either remove cable or dissable the wired network card and ensure you enabled DHCP in the router settings to automatically give the pc an ip address, ensuring that thw wireless card is also set to obtain an ip address automatically in the TCP/IP properties of the wireless network adapter.
Jun 21, 2007 | NetGear RangeMax WPN824 Router
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
