Question about Dell 3010cn Laser Printer
Dell 3010 Color Laser only printing 3/4 of the page!
Okay, for about 3 months this problem has been annoying me.
I replaced all of the tonors, cleaned everything.. Problem still was there, i was convinced it was the drum. So today I got the new drum in, installed it..guess what, problem still there.
The printer will only print 3/4 of the page perfectly, but it cuts off the the rest. It does this when I print black only, or with color.
The cables are all plugged in nice and snug. I don't know what else to do!
Please help if you can.
Thanks!
  • 49 Answers
Typically this happens when one of the toners are not locked completely into place. Try, forcefully, to reseat each toner.
What's happening is the laser is being blocked by the locking mechanism of the toner cartridge not closed completely.
Good luck.
Posted on Feb 27, 2009
  • Derek Feb 27, 2009
    Also try using the cleaning rod by opening the front door. Or the right side of the printer itself (not in the front, on the right side) another small door opens. Inside that door is a blue handle. Pull it out 20-30 times to clean the interiors. Try again. :)
What to do with 30.05 change "cartridge invalid refill" problem
Buy Original Lexmark Tonor.
If you refill tonor, you need a new "Tonor reset chip" - some tonor remaufacture will stock them. Cost less than $2
Aug 08, 2014 | Lexmark Laser Printers 34S0400 E 360D...
Toner missing
Try removing and reseating the tonor cartridge.
Try using another (even used) tonor cartridge to test.
Some cleaning of the contacts and/or sensors may be required.
Apr 04, 2014 | Konica Minolta Magicolor 1650EN Full Color...
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
Left side of page prints lighter than rest of page
You should contact Dell about returning these for a replacement, it sounds to me like a manufacturer's error.
Jan 27, 2010 | Dell 1320c Laser Printer
Everytime I turn on my printer and print the first
I took out all tonor cartridges and cleaned the printer tape/ribbon. I also took out the overflow cartridge and the tray that first collects the excess tonor and cleaned that out. We are good to go.....There was excess tonor stuck in the excess collector cartridge which did not allow the excess tonor to go down to the overflow cartridge.
Jan 11, 2010 | Konica Minolta magicolor 5430 DL Laser...
The cyan color only prints on 1/2 to 2/3 of the page then fades out to nothing
okay make sure your cartrage does not have a scatch on it and if it is full or empty
Aug 07, 2009 | Dell 3010cn Laser Printer
Cleaning the Dell 3000 CN
Dell 3000 CN has no printheads, printheads are on inkjet printers, this is a color laser.
On a laser there is nothing that you can clean with a software.
If printer is not printing replace toner cartridge or try reinstalling drivers.
If printouts are dirt, then the printer must be manually be cleaned inside, see Clean your laser printer safely with these tips
Feb 24, 2009 | Dell 3000cn Color Laser Printer
How to solve repeated paper jams in Dell 3010 laser printer
Replace the pick rollers. If you're out of warranty it'd be mighty expensive to have Dell replace them, but, if you call them, they can get you access to a website (I can't remember the name...sorry) that has walk through tear-downs with pictures of each and every step. (Only do this if you're handy and have time)
Otherwise, replacement is the next option.
Typically Jams on this unit are from worn rollers. :)
Good luck.
Oct 20, 2008 | Dell 3010cn Laser Printer
Dell 3010cn Color Laser Printing Quality
yes..it's almost certainly the drum..did you get a new one or was it simply refurbished?
Aug 20, 2008 | Dell 3100cn Laser Printer
Out of toner........ but not really.....
Print a Supplies Status page to see the actual pages printed...
To print the Supplies Status page from the printer, on the printer control panel, select
Reports Menu, Supplies Status, and then Print Supplies Status page.
If the page count from the Supplies Status page indicates that the toner should not be in need of replacement then you have a bad cartridge. Actually, the cartridge is probably fine but the chip on the cartridge has got a problem. Return the cartridge to O.D. and get another one. Unfortunately, chips that don't work properly in not all that unusual so HP has a pretty easy return policy.
Hope this helps.
Mar 07, 2008 | HP Color LaserJet 2600n Printer
Dell 3010cn Laser Printer Logo
149 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
