Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Setting up wireless printer
How can set my printer wireless? it was connected before but i change the modem and change the ip address. how do you assign a ip address?
    New Friend:
  • 48 Answers
To assign an IP address to a KM 3035 you need to select the system menu/counter button above the touch screen. On the left hand side of the menu you need to select Printer Defaults. From this menu you need to select Interface and than select the network tab from the resulting screen. Scroll down to highlight TCP/IP and select change. From this next screen you should be able to assign a new IP address.
Let me know if you need any further info.
Henry
Posted on Aug 15, 2008
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
I'm using an SB5101 and trying to use a new wireless router with this modem, but the set up is saying I have a static IP address... where can I find that on my computer whil I'm using my old router? thanks
I have one, after finding out how reliable and well-made they are. However, they can be picky during setup, especially since they have a rare 'config IP' address (the number you type into your internet browser's address bar to change the modem's settings). Click here >> 192.168.100.1
See this link for more info.
Mar 21, 2011 | Arris SURFboard SB5101 Cable Modem
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
Trying to set up LInksys WPS54G, connected as
admin user: blank
admin pws: admin
ssid: linksys
wep : none
to setup wireless
make shure you saved settings on every settings
Feb 12, 2010 | HP LaserJet 1320n Printer
Can't figure out how to connect my printer to the "network"... hope I'm using the right terms. Had it all set up to a dlink wireless router with a modem and had to disconnect it all to resolve another...
connect a lan wire from router to printer
print printer information
find out ip
pls add static ip address on the pc(printer and pc should be in one network)
type ip address on the internet explorer
change the ip address of your router class ip network range
remove static ip from pc
Oct 28, 2009 | Brother HL-2170W Mono Laser Printer
Cable Network Routing with Zyxel 600
You have to set different ip address. To clear this up this how I got my setup. I have verizon internet. I use a westell 6100g modem, I have the local ip address set for 192.168.1.1 and I got a linksys wireless router and the ip address set for 192.168.9.1. Then I plug my modem into the wan port and it works. What am I doing is setting a static ip address from my modem to the router and using the router to distribute my address through the network. If you have any printers on the network you need to change that numter to 192.168.9.x number. If you don't have two different numbers set the router will take over.
Aug 09, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
Help me with setting up a modem and a router
Are you able to get online directlty from modem? If yes check what is IP address you get from modem, if it is like 192.168.1.xxx, then you need to set connection type as DHCP(not PPPoE), and change router's local IP address to 192.168.2.1 , and reboot router and modem.You can try this steps:
1. Access the router setting via a browser.
2. On Setup, Basic Setup:
- Internet Connection Type unchanged as "Automatic Configuration - DHCP"
- Local IP Address changed from 192.168.1.1 to 192.168.2.1
- Settings saved
3. Clicked on Status to check if IP Address value has numbers (not 0.0.0.0). If you have zeroes, click DHCP Release then DHCP Renew.
4. Wired connection to internet OK. Wireless connection from a family PC also OK.
Good to go i thinks.Let us know.
Apr 08, 2009 | SMC Barricade 7004VWBR Wireless Router
Setting up a wireless router
first you have to check the ip address of the dsl modem you used and see to it that it is not the same ip address of the router to avoid conflict. the default ip address of dlink router is 192.168.0.1.if in case your dsl modem has the same ip address with the router, you have to change firs the ip address of the router before connecting the router to your dsl modem.
next you need to know your internet connection whether it is DYNAMIC or PPPOE, depending on how your internet provider configured your modem. for PPPOE connection, you have to know the USERNAME and PASSWORD that your provider provides you.
good luck.
carlmali007@yahoo.com
Nov 30, 2007 | D-Link DI-624M Router (DI624MRE)
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
432 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
