Question about Microsoft Office Professional 2007 Full Version for PC
Closing Outlook 2007
No matter which button I use to close Outlook (File Exit, the X at top right, or the Inbox Button Close command) I get an error when I start it back up. Is there a preferred process for closing Outlook 2007?
  • 36 Answers
Go to File, exit
Posted on Jul 26, 2008
How do i fix microsoft outlook?
Try these steps
* Click "File," then "Exit" to close Microsoft Outlook.
* Open Windows Explorer. Browse through your file system to where Microsoft Outlook is installed. On a 32-bit Windows system, this will be "c:\Program Files\Microsoft Office\Office XX," where "XX" is the Office version number. On a 64-bit Windows system, this will be "c:\Program Files (x68)\Microsoft Office\Office XX."
* Double-click "scanpst.exe." Click the "Browse" button and navigate to "c:\users\username\AppData\Local\Microsoft\Outlook." Double-click "archive.pst."
* Click "Start." The utility scans your archived PST file and reports any errors or corruption in the file.
* Click "Make Backup of Scanned File Before Repairing" if the Scanpst program finds errors. Click "Repair." Close the confirmation window when the repair is finished.
Or use Outlook Fix Toolbox http://www.outlook.fixtoolbox.com/
See more http://www.filerepairforum.com/forum/microsoft/microsoft-aa/outlook/669-how-to-repair-corrupted-pst
Jan 23, 2015 | Microsoft Outlook
When opening Outlook I receive the following message, this occurred after I tried to email a photo out of a photo program: "A data file did not close properly the last time it was used and is being...
1. In Outlook 2007, click the Tools menu and select Options.
2. In the Options dialog box, click the Mail Setup tab and then click the Data Files button.
3. In the Account settings window, you will see all of your personal Outlook data files listed. Here, you want to note the full path to each data file. On my system, my Outlook personal and archive folders are stored in the C:\Documents and Settings\Your Username\Local Settings\Application Data\Microsoft\Outlook folder.
4. Once you have this information, close the Account Settings dialog box and then close the Outlook Options window.
Now that you have the location of your Outlook data files, you need to check and repair them using the Microsoft Office Outlook 2007 Inbox Repair Tool-SCANPST.exe. By default, you should see SCANPST.exe in the Microsoft Office installation folder's "Office 12" subfolder. On my system, SCANPST.exe is located in C:\Program Files\Microsoft Office\Office 12. For additional information on SCANPST.exe, take a look at the Microsoft Knowledge Base article, "How to use the Inbox Repair Tools to recover e-mail messages in Outlook 2002 and Outlook 2003."
To check and repair your Outlook data files, follow these steps:
1. First, close Outlook 2007.
2. Use Windows Explorer to browse to SCANPST.exe, then double-click it.
3. When the Outlook 2007 Inbox Repair Tool opens, click Browse and navigate to the Outlook data file location that you found earlier. Note that you will need to check each file listed. On my system, I start with the file archive.pst. To check that file, you would select it in the "Select File to Scan" dialog box and then click Open.
4. Now click Start to begin the repair process.
Mar 05, 2011 | Sony Microsoft Office Standard 2007
Upon opening my Outlook "Personal Folders" I receive an error message indicating that I improperly closed the files at last session. What is the proper procedure for closing the folders? Thanks.Bill C.
This kind of message usually occurs when the computer crashes, or Outlook otherwise closes without completing the housekeeping it normally does when you close the program. If you are working on a laptop and it didn't recover from hibernating properly that might cause this kind of problem,
If you click File, then Exit to close Outlook in the future that should minimize or eliminate the problem.
Jan 31, 2010 | Microsoft Office Outlook 2007: Windows
Outlook express
hi,
Error 0x800c0133 when you are retrieving email with your Outlook Express (OE) is because of currupted Inbox file.
To remedy please follow these steps:
  1. Open OE, on the left pane, right click "Local Folders", select "New Folder...", specify a name for your new folder as "Temp".
  2. If you are still able to access "Inbox", move all mails in "Inbox" to the new "Temp" folder.
  3. Go to menu "Tools" -> "Options" -> "Maintenance" tab -> "Store Folder" button. It will show the location of your Inbox file, please remember this location.
  4. Close OE, go to the location mentioned above, delete the file "inbox.dbx".
  5. Restart OE, the "Inbox" folder should be auto recreated. Move back your mails to the new "Inbox", remove the "Temp" folder.
or
Another solution
Error Number:0x800c0133
Error Number: 0x800C0133 = a corrupt Inbox.
Move any mail you wish to save to a local folder you create. Then:
Tools | Options | Maintenance | Store Folder will reveal the location of
your Outlook Express files. Press the Tab key to highlight the folder
location, then Ctrl+C. Close OE, then Start | Run | Ctrl+V will put the
location in the box - Click OK and you'll see the OE files. Otherwise, write
the location down and navigate to it in Windows Explorer.
In WinXP, Win2K & Win2K3 the OE user files (DBX and WAB) are by default
marked as hidden. To view these files in Windows Explorer, you must enable
Show Hidden Files and Folders under Start | Control Panel | Folder Options |
View.
With OE closed, find the DBX file for the folder in question {Inbox.dbx} and
delete it. A new one will be created automatically when you open OE.
General precautions for Outlook Express:
Do not archive mail in default OE folders. They will eventually become
corrupt. Create your own user defined folders for storing mail and move your
mail to them. Empty Deleted Items folder regularly. Keep user created
folders under 100MB, and Default folders as empty as is feasible.
After you are done, follow up by compacting your folders manually while
working *offline* and do it often.
Click on Outlook Express at the top of the folder tree so no folders are
open. Then: File | Work Offline (or double click Working Online in the
Status Bar). File | Folder | Compact all folders. Don't touch anything until
the compacting is completed.
Turn off e-mail scanning in your anti-virus program. It is a redundant layer
of protection that eats up CPUs and causes a multitude of problems such as
time-outs and account setting changes. Your up-to-date A/V program will
continue to protect you sufficiently. For more, see:
http://www.oehelp.com/OETips.aspx#3
In Tools | Options | Maintenance: Uncheck Compact messages in background and
leave it unchecked.
Apr 16, 2009 | Microsoft Windows XP Home Edition
Personal Data File did not close properly
Hope this solves it for you! Here's the official word from Microsoft:
If you receive one or more of these error messages, you may experience performance issues until Outlook finishes the reconciliation process for the .ost file or for the .pst file. The following gear icon is displayed in the status bar while Outlook checks the data file in the background: Collapse this imageExpand this imageol2007gearicon.jpg When this icon disappears, the .pst file or the .ost file is reconciled. If you exit Outlook while the gear icon is present, reconciliation must restart the next time that you run Outlook. We recommend that you leave Outlook running until the gear icon disappears before you exit Outlook.
An incorrectly shut down .ost file or .pst file may occur for one of the following reasons:
  • Antivirus scanning of the file
  • Forced Microsoft Windows shutdown before the Outlook.exe process shuts down completely
  • Outlook add-ins
If you see this issue frequently, and you have to exit Outlook shortly before you shut down your computer, it may be better to shut down Windows while Outlook is still running. We recommend that you do this instead of exiting Outlook and then shutting down Windows shortly after that.
Dec 26, 2008 | Microsoft Office Outlook 2007: Windows
Run Outlook from a command line with the /cleanprofile switch appended to the command.
To find the correct command line, right click on a shortcut for Outlook and go to Properties. Copy the information in the Target field and Paste it to the command line. If there is already a command option, remove it and add /cleanprofile after the closing quotation mark. (Add a space before /cleanprofile)
For example, go to Start: Run. . and enter something like "C:\Program Files\Microsoft Office\OFFICE11\OUTLOOK.EXE" /cleanprofile .
Then add a new profile. Be sure to check the check box for "Set as default profile". Note: You cannot see this option unless you click on the "Options >>" button.
This should fix the problem.
Jul 02, 2008 | Microsoft Windows XP Professional
Will not delete from inbox outlook 2007
Try running scan PST
Close Outlook > Start > C drive > Programs file > Microsoft Office > Office 11 for 2003 , office 12 for 2007 > scanpst.exe > Browse to you Outlook pst file ie search for *.pst > Start > repair
Apr 29, 2008 | Apple iPhone Smartphone
Outlook express
dear fando,
This is usually down to a corrupt or over-full email inbox. Outlook Express is not very good at holding large amounts of emails especially if they have large attachments. I had a user this morning with a 2.5 GB inbox.
Backup/rename Inbox (C:\Documents and Settings\(User)\Local Settings\Application Data\Identities\{GIU}\Microsoft\Outlook Express\inbox.dbx -> inboxbak.dbx).
Close Outlook Express.
Open Outlook Express.
Outlook Express will have created a whole new Inbox.
Your email should now work.
Best wishes.
Jan 04, 2008 | Audio Players & Recorders
Outlook 2007 slow on closing and crashes on open
Your computer might be using caching. Can you tell me how much RAM you have on your computer? If you have 2GB of RAM i would recommend disabling the caching. This slows down the system quiet a bit (since it uses miliseconds instead of nanoseconds). Your computer is as fast as the slowest component.  I would also suggest defragging the drive.
Oct 14, 2007 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
