Question about Jensen VM9411 Car Video Player
JENSEN VM9311TS DO I HAVE TO HOOK THE BRAKE WIRE UP AT ALL?
DO I HAVE TO HOOK THE BREAK WIRE UP AT ALL??? OR CAN I JUST DO THE SOFT HACK CODE WITHOUT HOOKING UP THE BREAK WIRE??? YOU MIGHT HAVE ALREADY ANSWERED THIS BUT I JUST
NEED FURTHER CLARIFICATION ON HAVING THE BRAKE WIRE CONNECTED OR LEFT DISCONNECTED IN ORDER TO DO THE CODE STEPS YOU RECCOMMEND.......
  • Anonymous Feb 27, 2009
    how do i hook up the parkin brake wire
  • 1,586 Answers
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 01, 2008
Bypass brake code VM9311YTS
just connect the pink wire to the ground wire. some will tell you that a menu will pop up if so just input the numbers 5,4,3,2,1,0 make sure you hear a beep after every number. the menu will look like a hammer icon. im not sure if you have to input the code because i didnt need to
Apr 01, 2009 | Jensen VM9020TS Car DVD Player
Jensen vm9311ts dont kno where pink wire goes or anything
go to www.google.com then type JENSEN CODE and get the first option .
Feb 27, 2009 | Audiovox VM9311TS
How do i bypass parkingbreak for a jensen 9311ts on mustang 99
take the parking brake wire should be pink or some funky color and hook it up to a +12 power source.
that way there is no need to use the e brake or anything for it to work
But as a word of caution all this is illegal in most states due to people not keeping their eyes on the road. ive read of people getting tickets for having disabled this security feature on their stereos. some insurance companys will not cover you if there's an accident you are involved in and you by-passed the safety feature. so before you do it, be sure to read your local laws and check with your insurance agent before doing it. you will not be happy finding things out the hard way.
Dec 02, 2008 | Audiovox VM9311TS
BackGorund Change on a Jensen VM9311TS In-Dash DVD player
There is no e-brake override code. You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Sep 24, 2008 | Car Audio & Video
Jensen vm9311ts car tv
ground green pink wire
problem fixed
Feb 10, 2008 | Jensen VM9510 Car DVD Player
Trying to find the parking brake
YOU DONT NEED TO HOOK THE PINK WIRE UP JUST PUT IN A DVD AND TYPE IN 543210. THIS IS A BYPASS CODE SO YOU CAN PLAY DVD WITHOUT HOOKING UP THE PINK WIRE. YOU MUST HOLD DOWN THE 0 FOR 4 SECONDS WHEN PUTTING IN THE CODE.
Jan 15, 2008 | Jensen VM9510 Car DVD Player
Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Sep 21, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
No hook up guide
Please update your post with the Serial Number of your Player and I will be able to help you.
Jul 31, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
470 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
