FixYa.com
Tags:
HP HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A  CD-ROM Drive
Laptop
posted by jayjayaustin on Jul 26, 2008
I have a HP Pavillion ZV5000, and the charger end will not charge, It has been a problem for a while, but if I plugged it in just right it would charge, know it will not. I belive the problem is with the connection in the computer.
Cant this be repaired and if so how much would it be, and would it be worth repairing or should I just give up and get a new laptop?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 12, 2008
Helpful (85)
Maanita
Rank:Wiz Wiz
Rating: 83%, 220 votes
please check first that does the notebook work fine on the battery mode.
if system does not work on battery mode also it is a fault of the board that would have to be replaced
if it works fine on battery, then the problem could be with the adapter
to check the same, please try using another adapter or the same adapter on another hp notebook.
if the adapter does not work on another notebook, please get the adapter replaced.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these CD ROM Drives problems?
HP HP Pavilion ZV5000, ZV6000, ZX5000 Series...
sound problem
Hi! I do not have a driver for... Answer This...
Hp Pavillion zv5000
Hey, i got a Hewlitt Packard... Answer This...
Moue Malfunctioning
Hi I have a problem with my... Answer This...
HP zx5000 won't stat
my HP zx5000 starts up and... Answer This...
Vertical lines in my laptop...
Hello! I've been using my... Answer This...
Repair Service
Find CD ROM Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
