Question about HP Pavilion dv6000z Notebook
Laptop I have a HP Pavillion ZV5000, and the charger end will not charge, It has been a problem for a while, but if I plugged it in just right it would charge, know it will not. I belive the problem is with the connection in the computer. Cant this be repaired and if so how much would it be, and would it be worth repairing or should I just give up and get a new laptop?
    Scholar:
  • 163 Answers
Its a shame the litigation and settlement has expired as were legal consultants for the plaintiff side on this case. If you bought this machine new and HP failed to contact you you should contact skamber@kamberedelson.com to let them know. I have a list of individuals they failed to notify. Weve repaired thousands of these and a better DC jack as well as the Schottkey rectifier should both be replaced. If you need more help just yell back.
Posted on Jul 27, 2008
    Genius:
  • 2,028 Answers
Yes this can be repaired, and I believe this to be a good machine and worth it. The cost for a jack repair is approx $100 at most smaller computer shops. Bestbuy, however, will be a heck of alot more expensive. You should have the jack repaired ASAP. A loose or broken jack can cause an electrical arch which can, in turn, cause severe damage to the machine. Damage that may force you to buy a new laptop.
Posted on Jul 26, 2008
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
System failure in my laptop ??
Remove the battery from the computer and plug in the correct charger and see if it will power on. without the battery. if so turn off and put battery back in with power connected see if it powers up.
Oct 29, 2007 | HP Compaq Presario 730US Notebook
No power from cord to computer
Hi...
If your laptop is under warranty go back to the manufacturer. If not go to hp center and buy a power cord of your charger which is totally fix to the charging hole.
Good luck
Regards
PCmania
Sep 25, 2009 | HP Pavilion dv9000z Notebook
HP Pavillion ZV6000 - Charging Problems
hi
It seems that your laptop is not charging so in that case you must take your laptop to your vendor.For more support you can visit---------http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
Jun 22, 2009 | HP Pavillion ZV6000 Notebook
My HP Pavillion zv5000 power problem
Just fixed mine again!
you need to solder 2 wires to the computer connection then chop of end of cable so that you can solder together. Make sure you get them round the right way!
Apr 07, 2009 | HP (350827-001) for Pavilion ZV5000,...
I got an hp pavillion zv5000 dont have power on / bios passw
Sorry to say, but I think you'll need to contact HP support on this. They have a great chat feature that they can help you on.
I just think most people will be hesitant to assist you with bypassing passwords, but I could be wrong!
Hope this helps, anyway.
Mar 28, 2009 | HP Pavilion zv5000 Notebook
What is largest HDD and mem card can I put in HP Pavillion ZV5000
According to the HP website , the biggest hdd that you can put is 80GB and memory is 2 gb.
Check the following link for more
http://tinyurl.com/ch6hn7
Select the mdel number and proceed with part search
Thanks
proton
Mar 12, 2009 | HP Computers & Internet
HP Pavilion ZV5000 Charger
HP has a cord that plugs into the right side of the zv5000 that is intended for use with a docking station that they sell separately. The connector has a blade with a bunch of connections, but I only use 2, power and ground. The outermost contacts are power +and-. I bought the cord - re-wired my power cord to the new cord power wires - takes some figuring to determine correct wires - soldered them up and it has worked great for 2 years - much better connector also - squeeze side tabs to plug in or un-plug. This solution was about $25 if I remember - compared to $135 that the shop quoted me to replace the internal MB power connector
Oct 17, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Laptop
please check first that does the notebook work fine on the battery mode.
if system does not work on battery mode also it is a fault of the board that would have to be replaced
if it works fine on battery, then the problem could be with the adapter
to check the same, please try using another adapter or the same adapter on another hp notebook.
if the adapter does not work on another notebook, please get the adapter replaced.
Jul 26, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion dv6000z Notebook Logo
294 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
