Blue will not adj on akai 42 plasma odel pdp4206EA
  • 2,326 Answers
How old is your Plasma?
Could you please give us more info about you TV?
How the blue color can not be adjusted?
Posted on Jul 26, 2008
  • 2,071 Answers
It is convergence STK chips IC problem,replaced this two STK, so it will normal again...
Hope this may help;
Regards,
VOTIT
My tv picture is bouncing up and down
may be there is a problem in setting of ur colours
Jun 07, 2008 | Akai PDP4206EA Television
Got a blue vertical line on me plasma
Ohh you have a problem with the PLASMA gass ( RGB balance failiure )..don't switch it on again run to service center....
causes ;- heavy nonstop use, heavy impacts , can have probs from LG factory , we have nothing to do the only advice is run to a service center...don't try to do it yourself ....
so i identified your prob...PLEASE VOTE ME AS "FIXYA" (Successfully solved) for my help
May 29, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
AKAI PDP4206EA 42" DARK PICTURES ON COMP 1 AND 2. BLACK AND WHITE unstable vhold ON COMPOSITE. TUNER NOT TUNNING CABLE CHANNELS. ONLY LOOKS GOOD THROUGH VGA. WHAT COULD THE PROBLEM BE?
I had the same problem... It's the main board. Unfortunately they're pretty scarce these days. You can try to get a Viore mainboard, but you're either have to make a 3.3v ttl serial cable, or desolder the flash from the akai board and put it on the viore board (the two tv's use different pdp's). The 1st option is a little less intense.
May 04, 2009 | Akai PDP4206EA Television
AKAI PDP4206EA 42" DARK PICTURES ON COMP 1 AND 2. BLACK AND WHITE ON COMPOSITE. TUNER NOT TUNNING CABLE CHANNELS. ONLY LOOKS GOOD THROUGH VGA. WHAT COULD THE PROBLEM BE?
this is a shot in the dark but as the set been dropped? have you tried tapping around the case to see if this ulters the brightness. you might have a hairlined crack in the main pcb or dry joints.good luck .farr64
Apr 29, 2009 | Akai PDP4206EA Television
Part Number for AKAI PDP4206EA
Here are some links for most of the boards for this Akai model # PDP4206EA from a major parts distributor:
Akai PDP4206EA Replacement Part ATSC Digital / HD Tuner Board
Akai PDP4206EA Replacement Part Main Board Assembly
Akai PDP4206EA Replacement Part NTSC Analog Tuner Board
Please note: The X-SUS and Y-SUS boards and power supply board are no longer available and the video board is part of the main board assembly. Hope this information helps.
Feb 04, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Akai Plasma
Had a friend with same problem. Found out to be a lightning strike. Strangely enough, the colour came back 4 months later on it's own.
Not much help, I know.
Nov 04, 2007 | Akai PDP4206EA Television
A WONDERFUL MAN NAMED LARRY AT 251-479-3567 HELPED ME WHEN AKAI WOULD NOT CALL HIM.
Apr 14, 2007 | Akai PDP4206EA Television
Akai 42" PDP4294 plasma
Did you change the "refresh" settings on your PC? Set your resolution forst to 800 x 600 then go and change the refresh to a lower number like 60hz.
Mar 22, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
