Question about Zebra Stripe S500 Thermal Label Printer
Zebra S500 incompatibility with XP SP2??
I had a Zebra S500 working great until I installed SP2 on XP Pro. Now it won't print. Anyone else seeing this? does anyone know of a driver that will work with SP2? I found the 95 version, the 3.11 version and the 2K versions. I have to travel to work on the printer so I have not had a chance to try them all yet. I was hoping someone may have some info. thanks in advance
  • 2 more comments
  • ZebraS500 Jul 26, 2008
    that is a dead link, could you check it and repost it? thanks!
    the link is dead. can you check it and repost? thanks
  • Anonymous Oct 16, 2008
    i have the same problem. it was working with windows 2000. Now i have XP Pro and it is not printing. any idea how to get it to work ? Thanks
  • Anonymous May 12, 2009
    This will print with the strandware driver but not with any windows driver. Any suggestions?
    Genius:
  • 1,027 Answers
Try the re-installing latest driver:
http://www.zebra.com/id/zebra/na/en/index/products/printers/industrial_commercial/s4m.html
Posted on Jul 26, 2008
Zebra TLP 2824 Plus does not print barbell labels
You need to run win7 in XP mode. I am not sure the Zebra software will run in 64bit.
Feb 27, 2017 | Zebra Office Equipment & Supplies
HP dc5000 compaq - running win xp pro sp2 and it won't upgrade to sp3. Sp3 needed to run Nero 11.
go to this link http://www.microsoft.com/en-us/download/details.aspx?id=24 download winxp sp3 exe follow instructions disregard for IT professionals and developers this is the download you need after installing goto windows update and download and install updates
Aug 24, 2012 | HP Computers & Internet
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
Problems when replacing defective zebra with another
Here's a manual if you don't already have one:
http://tinyurl.com/yb2rpd4
Loosen the plastic thumbscrews that tighten the printhead down onto the ribbon and media. Perhaps there's too much pressure, not allowing the media to advance.
Also just try to reset it to the factory defaults.
Hold down FEED and PAUSE while you power up. When it's finished resetting, press MODE 4 times to save the settings. I've had to do this quite often with ours.
Good luck! I hope this helps. If so, please leave a rating!
Jun 17, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra S500 no print
You can find the manual in www.zebra.com, and try reset, pressing FEED and PAUSE keys and turn on printer, release keys until move labels.
Mar 12, 2009 | Zebra Stripe S600 Thermal Label Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Zebra S300 printer pauses without printing additional copies
I Use driver from Nice Labels
http://www.nicelabel.com/downloads/nicedrivers/zebra seems to work fine
Dec 05, 2008 | Zebra Stripe S300 Thermal Label Printer
Zebra LP2824 Not Printing
I had the same problem and could not fix it but called Zebra headquarters and they gave me this solution and it works! It sounds crazy but it works. Turn off the printer on the switch on the side. press and hold the button on the front of the machine while you turn it on. The light will turn red then release the button the light around the button will then turn a solid greed then blink green. While it is blinking green press and hold the button again until it the light turns orange and then release the button. This apparently puts your printer into line mode or something but anyway it works!
Oct 02, 2008 | Zebra Eltron LP 2824 Thermal Printer
How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
Oct 30, 2007 | Zebra Stripe S500 Thermal Label Printer
Zebra Stripe S500 Thermal Label Printer Logo
799 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
