Question about Mitsubishi CS-27205 TV
Dominant blue my 55 inch cs27205 has just lost its original color and is dominant blue and darker. i am unable to properly adjust the colors using the vidio adjustments on the remote. any sugestions.
    Problem Solver:
  • 9 Answers
Can you post to the party who has too much green how to adjust the video adjustments? They need to know so they can see if
its just a simple adjustment.
In your case, first turn the color level clear down to where you
have a black and white picture. As in the case of too much green,
question is if the picture is black and white or if there is a color
on the screen so its blue and white? I suspect it will be which
is typical when the guns start to fail. Likely the green and red
guns are weak in output. There are screen adjustments in the set that a tech can set up that may help some, but the only real fix is to replace the guns which is expensive and requires a complete allignment. All 3 guns need changing to get it back to spec and it is a good idea to replace the flyback for reliability. Get an estimate and likely you can replace the set for the same money.
Posted on Feb 21, 2009
How to adjust the color on a HP Officejet 4635 Printer? The is much darker and "off" color from the original picture.
Colour control is not a function of the printer. You need to adjust your PC/laptop display to show a more realistic image by sourcing some test patterns, see link:
http://www.lagom.nl/lcd-test
When your screen is properly set up, open the picture you want to print and see what it looks like. Use a suitable photo editor to adjust brightness, contrast etc. and then try printing again.
Jul 12, 2016 | HP Office Equipment & Supplies
Its glittery white because i briten the color but when darken it gets green
you must re-adjust in the RGB (Red-Green-Blue) setting. depending on the brand of your TV, because there are set manually from the TV (you must open the cover of the rear of the TV). and there is a set directly from the remote only, with the open "factory settings", then you can re-adjust RGB color, especially green, not too dominant with the other colors (RED-BLUE). how to set is that you need to neutralize the color, (color TV sets to zero level) so that the image becomes black and white. if the green is too dominant, then Decrease the level of Green Bias or Green Cut off/ G-drive.
Aug 05, 2010 | Televison & Video
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
My set is the SAMSUNG LHP5063W. I replaced the color wheel Sunday and got horrible colors. The Part number ordered was BP96-00674A The number on top of the color wheel top is L3 BP61-01687A but I do n
The new color wheel is different from the original. The original used an Air Bearing type motor. But the replacement type is a standard bushing type motor. There is a jumper on the rear of the DMD board that may or may not be covered with a paper sticker. Reposition the jumper to accommodate the new color wheel.
May 21, 2009 | Samsung HLR5064W DLP Projection TV
No red
Losing one colour probably means failure of electronic components related to the particular colour. It is unlikely adjusting the red settings will fix the problem. Even if it did, the colour balance needs specialist equipment to properly set up.
Mar 25, 2008 | RCA F32450 32" TV
Green Picture.
i suggest to have it check by a qualified service technician. there seems to be a problem with your crt (cathode ray tube). because inside this projection tv are 3 crt guns responsible for color red, green and blue, which only qualified technician can adjust it and replace if it is necessary.
Jan 15, 2007 | Philips 55PP9701 55" Rear Projection...
Televison & Video Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
