Question about Eureka 4874 Bagged Upright Vacuum
Hose has no suction
My Eureka 4870 series "The Boss" has no suction on the hose function.  I have  cleared the hose and the tubing between the hose and the bag.  I cannot find what is casing the lack of suction.  Any suggestions?
  • aliciasteele Jul 26, 2008
    Even in the upright position, the hose does not function.  I cleaned all the hose/piping out, disconnected the bag from the vacuum to check if anything was blocking the airflow, and changed the bag.  There is not any change in the suction level.  When I place my hand on the hose when it is in the hose function, I feel NO suction at all.
  • Anonymous Oct 29, 2008
    I have the same problem! I am so frustrated with it right now because I just got it a few months ago...
    Genius:
  • 1,027 Answers
Most uprights need to be in the up-right locked position to enable the hose pickup.
Posted on Jul 26, 2008
Eureka Smart Vac The Boss no suction from either setting. I have taken it apart trying to see if it was clogged but it isn't. Checked the hose it is not sliced.
Remove the bag cover and feel for suction above the motor. If their is suction there then check the bag compartment is sealed. You can drop a coin down the hose to check for blockages all the way to where the bag attaches.
Aug 16, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have no suction through the tube so unable to clean with attachments. Why?
Its plugged up. Remove hose from appliance, and see if the cleaner sucks. If so, pull hose in a straight line and push a broom handle through the hose to clear debrie. Re attatch hose and this should clear the blockage
Dec 04, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
No suction on my eureka boss smart vac. The belt is fine and the roller moves. I just changed the bag but no dice. any insight?
I know this is an old question but this is a good vac and maybe I can help somebody else some day, wish I'd figured this out a couple months ago when this problem first started. :} Anywho, this is another option from an amateur; I don't know the right terms but here goes: Right below the yellow flow knob (Floor/Hose) are the tops of two hoses, one to floor beater, one leading to hose. There is a sort of black clip holding these in place. Open it up, it hinges toward the front of the vacuum. On the back of the vacuum to the right of the lower cord wrap is a gray screw-looking thing, with little pix of locks imprinted above - one locked, one unlocked. Turn the screw toward unlock. Take the top of the black tube that leads to the hose and maneuver it out of the hole it's in, and you may find your clog in the top there. I found just a handful of dog hair, leaves and sticks stuffed in that tube but it was dense enough to stop flow to the hose. Removing it fixed the problem completely.
Aug 15, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Something is stuck in my hose on the eureka boss smartvac, can i dtach plastic hose on side
yes, there are a few screws that need to come out to do so, u can also use a coat hanger to loosen it up and turn it on, the vac will **** the loose dirt into the bag/canister
Jul 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Mar 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 4870 hose assembly replacement
Boy, it's been awhile since I took one of these hoses off, but I think at least one of those plastic hose guide things has to come off in order to remove the hose. Those screws that look like they cannot be removed are probably torx screws which need a T20 torx scredriver that you can get at any hardware store. That is the most common size torx screw that Eureka uses.
Here is a link to the owner's manual in case you need any diagrams for getting the clear tubes off:
http://www.eureka.com/service/manuals/70750.pdf
Hope this helps. :-)
Oct 17, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Tear in Eureka Upright "The Boss" 4870
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=652524
Posted by kdunnett on Jun 07, 2008
I have a tear in the hose of an upright Eureka "The Boss" 4870 vacuum. I cannot find how to release the parts I need to get the hose out and put in a new hose (which I already have) I've searched the Eureka site and the owner's manual - nothing about how to replace the hose itself. Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. In answer to your question, the owner’s manual may or may not give an example to install the hose only, but on most vacuums the hose sometimes will screw in to the hose cuff on both ends unless if it is a hose assm then it will then twist and turn. Check with the
Eureka website and have them send out a schematic and owner’s manual for you so that you can install your hose properly. Sometimes you have to place hose glue on the end of each side in order for the hose to screw in properly. the website address will be listed below and they certainly should supply you with the owners’ manual and maybe a schematic of the parts breakdown that also may help. If not; check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 07, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Eureka 4874 Bagged Upright Vacuum Logo
267 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
