Question about RCA WSP155 Main / Stereo Speaker
RCA Wireless speaker
One of my speakers will not power on at all???
    Problem Solver:
  • 7 Answers
This happened to one of ours, it turned out that the plug was damaged. Try using batteries and see if it will work, if so, you know that you need to just get a new adapter plug. Good luck!
Posted on Aug 28, 2009
Rca grounding sound with samsung smart tv
I see you are using wireless speakers. The biggest problem with the residential grade is everything interferes with them. Make sure you are moved as far away from power sources as you can be. Direct line of site is not optimal but a fix as well. The wire you have connected for the send receive could be the issue as well. a shielded heavier AWG will help as well as grounding from the source equipment and dropping the ground on the other side.
Apr 13, 2014 | Parrot Zikmu Wireless Stereo Speakers by...
I need a transmitter for a set of rca wsp150 WIRELESS SPEAKERS. CAN I SUBSTITUTE? Where can I buy one?
head phone set WHP141 will work with that set of speakers, look on Ebay
I have a set of the same speakers.... make sure that your transmitter is actually bad, it does not power up with the GREENLIGHT staying ON UNTIL the sound source is hooked up and has enough INCOMING volume to trigger the transmitter on.........
Oct 27, 2011 | RCA WSP150 Main / Stereo Speaker
Rca 155 Wireless Speaker transmitter not working. Power Led flashes then goes out???????
You probably have the polarity on your plug to the transmitter set on the wrong one. Set it to negative frequency, and it will probably work. I've had the same problem myself.
One other possibility: the Music has to be coming through for the light to go on, so if the music is too soft, you might not get any sound through. Good luck!
Jul 16, 2009 | RCA WSP155 Main / Stereo Speaker
Wireless speakers to audio devices having no audio output
you can find all kinds of adapters for RCA or phone jack to anytype of connectors at best buy or circuit city, if not Radioshak probably have them. just ask for a cable adapter to the type of connector transformation you need for the speakers.
Dec 30, 2008 | Computers & Internet
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Speakers
the speakers need a power source. as long as they have that, all you need is a phono plug, or a system that uses line level audio with rca plugs.
Dec 04, 2008 | Liesegang Multi 800 video projector + 2...
Problem adding wsp155 wireless speakers.
You must check with the instalation gude for the wireless speaker to see if the connection to the reciver is a high impedence or low impedence... If its like most wireless set-ups its going to be a high impedence output from the reciver to the transmitter part of the speakers. That would be from the RCA jacks in the back of the reciver maked line out or tape out. If you want to use them for a specific speaker output , some recivers have an output jack that would be labeled center sperker out but would be an RCA type jack ect ect. If your reciver dosent have that you can in a higher end audio store get an adaptor to convert the speaker output to a high impedence, But I dont recomend that as some of the adaptors do cause excessive strain on the output section of the amp or reciver.. If you buy a good one though you should be fine.. You get what you pay for.. Good Luck
Aug 06, 2006 | RCA WSP150 Main / Stereo Speaker
RCA WSP155 Main / Stereo Speaker Logo
97 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
