Question about Samsung Digimax i50 MP3 Digital Camera
Horizontal lines across ALL pictures
I'm getting strange horizontal lines across my pictures.
It seems to be on ALL the pictures I take now, and I don't know why it's doing this, or how to fix it.
Here is an example:
It is only on the background on this particular picture, but is more prevalent on other pictures (which were so bad I never posted them anywhere)
Any ideas or suggestions?
  • chrissy-may Oct 11, 2008
    I have this problem too.
    It only happens when i am in bad light and don't use a flash.
    The unfortunate thing is this happened just after my warranty ran out.
  • prinsess_1n_ May 20, 2009
    Same thing here i need help fixing it
  • 206 Answers
SOURCE: Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
Everybody here seems to have basically the same problem so I will write a general fix for these Samsungs. First what you got is known as Convergence failure, A Ic or resistor, fuse or some other component has failed in the convergence circuit. So finding the service menu and trying to align the colors or spinning magnets on the CRT’s or a real bad idea of tipping a CRT or mirror would be the equitant of ripping the transmission out of your car because it had a flat tire. When the convergence fails no adjustment will bring it back, and if you do one of these stupid things then you have two problems. Now most of these Samsungs have an easily replicable board that all the convergence amplifiers are on. This can be found by removing the back and seeing if there is a board about 9 X 5 inches big and mounted to the CRT mounts, there will be 5 connector to this board. Now if your set does not have this board and instead has the two convergence Ic’s (these are about the size of a playing card and have the numbers STK392-040 on them) mount down on a board below and to the right ( this is known as the deflection board) this repair will not work for you. Instead you will need to component level repair the convergence circuit. But if you do have this separate convergence board the repair is fairly straight forward. Go to or some other supplier and order BP95-00142E this is the convergence board. This board has been crossed several times through the years but this is the current version. Now once you get this board simply replace it making sure to get al the connector back in there original spot. The fire up the set and run Flash focus and for about 95% this will fix the set
Posted on Feb 13, 2008
SOURCE: White-out of outdoor scenes
This was not a solution; it was the problem.
I had a new shutter installed by a professional for $85. It now works pretty well but I bought another digital camera.
Posted on Mar 22, 2008
  • 48 Answers
clean the lense
you stupid arse
Posted on Jun 26, 2008
SOURCE: pink pictures
Have you tried changing the White Balance. You can access this by switching on the camera, pressing the Fn button and then the left arrow.
Posted on Jun 24, 2009
SOURCE: My camera seems to short out and there are horizontal lines in the pictures.
get new batteries, if recharging your current batteries does not work (to stop it shorting out).
reduce your shutter exposure, by changing to Manual Mode (M), selecting +/-, and then the left button (flash) around the Menu OK button. Mine works fine at 1s shutter speed, but was showing horizontal lines before that ...
Posted on Jul 09, 2009
Horizontal Lines in Picture, Picture Possibly Dimmer
The dimming is usually caused by the mirror needing polishing. The lines floating across the screen is usually caused by failed caps on the FMT board you can get the V26 FMT repair kit from
Jul 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Magnavox ts2543 with a single horizontal line
Most Probably the Vertical Output IC has failed. If it has, it also could cause resistors that supplt the +/- Voltages to the IC to fail as well.
Hope this helps,
Jun 20, 2009 | Televison & Video
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Horizontal LINES
If you are getting fine horizontal lines thet means the picture is over exposing. most probably the apparture or the shutter blade mechanism is not working fine. needs repairs.
Jan 19, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
White horizontal lines on screen
Replace all electrolitic capacitors on the Proscan pcb.
Dec 11, 2007 | Televison & Video
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
Cameras Logo
201 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
