Question about Mitsubishi WS-65513 65" Rear Projection HDTV
WS-65513 DM board caps replaced but green light continues
I have I have a WS-65513 and have replaced the 4 capacitors in C9B01, C9B02,C9B10, and C9B11 with the identical 1000uf 16V 105 degree caps. This only took me about 45 min once I found them, but the green light continues. I have not been able to find any other caps are visibly blown. Any ideas? If you could please e-mail me the service manual to Philipp@Rauch.us
Thanks
    Problem Solver:
  • 5 Answers
If I remember correctly, there are more than 4 caps on the DM board that need replacing.
Posted on Jul 25, 2008
Replacement Caps green blinking light
Someone gave you the wrong information. The caps on the WS65513 C9B01, C9B02, C9B10 and C9B11 should be replaced with 1000uf 16V 105 degree radial capacitors.
Jul 25, 2008 | Mitsubishi WS-65513 65" Rear Projection...
My tv
Good Day, fidel59;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 15, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Need a repair solution e-mailed
Good Day, jnjetsn;
Jul 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking green light
Good Day, pipe filtr;
MITSU 65513 BLINKING GREEN LIGHT WONT POWER UP
Good Day, xbossux;
Jul 09, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 green blinking light
Good Day, nixonam;
Jul 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513
Good Day, nixonam;
Blinkink light
Good Day, jcarnell;
Jul 05, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv
First wait 90 sec. after power is applied before turning on. If still blinking forever "this is a common problem with the mitsubishi V23 chassis, There are four 1000 UF capacitors in the DM module that go bad. Location #'s c9b01,c9b02,c9b10 and c9b11. The DM module is the large steel card cage on the left side when looking inside with the back off. Once you get the cage out, remove the board. The caps are the larger ones on the top of the board. They will more then likely be bulged out on top or exploded. Replace with 1000 UF @16V or better. This should get you going again. I've done about 15 of these repairs in the last year. Note: try not to mangle the copper grounding fingers. Good Luck.
Jan 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
