Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony kv-32hs500 Three days ago the tv just shut off and the standby light started flashing a 7 flash sequence. The tv would not turn on the rest of the night. Next morning the tv turned on again but after turning it off it would not turn on the rest of the day. This morning it turned on again and I was going to just leave it on all day but my wife shut it off on me. It will not turn back on. We do get a 6 flash sequence as well at times. I will try again in the morning.
  • 3 more comments
  • tazsman629 Aug 09, 2008
    having the same extact problem light blinght 6 times go to standby
  • nfoxtail Oct 02, 2008
    1. i paid several hundred dollars for my kv 32hs500 sony tv. ihave concluded the biggest reason for our problems not to mention other models is the fact that these tv s are made in mexico. and that is bad. as i have done lots of research on assembly practices. i say dont buy another sony.. trash it and forget it . end of story. john in ga.
  • Anonymous Dec 26, 2008
    I have the same problem. My tv starting to work again and now it won't turn on anymore.
  • horaceh8526 Dec 26, 2008
    When I turn on my tv and the light start to blink 5 times or when I hear the static sound, the tv should turn on. But when I didn't hear the static sound when I started to turn on the tv, that means the tv won't come on after 5 or 7 blinks. It all started when I keep on pressing the power button on my remote and then it happend.
  • mmitchellpls Jan 08, 2009
    I'm having the same problem with my Sony FD Trinitron KV-32HS500. It started about three weeks ago. I wasn't able to turn on the TV with the remote or the power button on front of TV. No sound or picture, just 7 blinks (sometimes 6) of the standby light, pause then 7 blinks again, etc... . After a day the TV would turn on again. Then it wouldn't come on for a couple of days, but would then work for a couple days. I'm now on the TV doesn't turn on cycle and it's been 3 days. Please help.
  • 3 Answers
Most probably the IC504 (Sharp PQ05RD21) on A-Board went bad. This model TV, including mine, is notorious for having this problem. The IC is rather easy to find and inexpensive (around $2.50). Your main problem will be desoldering the old one and soldering the new one.
Good Luck.
Posted on Jan 04, 2009
Im having a problem with my TV turning off and the standby button flashing 7 times, after it shut off. What can I do.
hi,
Blinking led in sony tv is its self dioganising function. 7 blinks by it means the horizontal output voltage increased above 33k.
You have to check the power supply stage of you tv. Normally in sony tv dry soldering can happend in the power supply stage. It will lead to unregulated voltage output from the power supply. Resolder all the points in the power supply section it will solve your problem.
ok
Jul 07, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
KV-32HS500 WON'T TURN ON standby light flashes 7 and sometimes 6 times and has flashed 4 times also.
These are sony error codes while in protection mode. The 7 blinks means high voltage exceeded 33k volts ,caused by either horizontal or power supply circuits.
The 6 blinks code is for no horizontal deflection, and the 4 blinks code is for no vertical deflection.
So the one thing they all have in common is the power supply that will need to be repaired before you can use the set again.
Hope this help. Good luck
Please do not rate this answer(unless it helps) as it is only a suggestion/information.
Dec 02, 2009 | Televison & Video
Standby light flashes but tv will not turn on
Ur high voltage is dying.The block of plastic with a red wire with a cap hook to ur CRT(tv tube).The FBT,it call the Flyback transformer,that is dying.That must be replace.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
TV wont turn on, sandby light flashes 7 times.
Any malfunction associated with a flashing stand-by light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony trinitron KV-32HS500 won't turn on, stand by lights flash 7 times. If we leave it off for a day or 2 then it will start again. What is wrong and how do I fix it?
I have this Sony KV-32HS500 DA-4 chassis complete service manual,i can email you the power supply circuit or any other parts you may need.Its about 18 megs in size.
Sep 06, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My sony kv32hs500 just stoped working and standby light flashing
sir you need to un plug your t.v set and plug it again to reset the memory setting...
Aug 06, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony kv-32fs120 tv
I have a
Sony KV-27S42 and its blinking 4x then pause and 4x again. help please!
Jun 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv-30xbr910 my tv won't turn on and the standby fashes 7 times
Good day.
Your unit has issues with the high voltage section. Particularly the vertical and horizontal sections. Blinking lights indicates that your flyback is not osscilating to distribute the supply to the sections. Please have it checked by a repaiman.
chris
Mar 21, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
I have the exact same problem! I'm assuming it's time for a new tv.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
239 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
