Question about Whirlpool Kitchen Ranges
Whirlpool gas range
My electric ignition has quit working. I have to light the burners with a match. Occasionally, tho, if I have the oven on at the same time the burners are on, the electric ignition will start clicking, and the burners will work fine for a few days, then they stop again. Thanks for any help with this problem.
  • llc1 Jul 27, 2008
    Thanks so much for your advice. I will have it checked out.
  • 254 Answers
You may have a bad spark/ignition module, it is located under the main top (on most models) and tells the burners too spark
Posted on Jul 25, 2008
The electric igniters for the stove burners stopped working. All four stopped at the same time.
If all 4 stopped working at the same time, the problem is with the spark modulator.
If the igniter is working on several of the burners but not on another, (or any variation), the problem is with the igniter wiring harness.
By design, the igniter for each burner is daisy chained in the wiring harness such that if one goes, the others will still work.
Mar 24, 2015 | Magic Chef 31000 Gas Kitchen Range
Whirlpool WFG361LVS2 oven. Broiler and burners ignite but oven will not. I can hear gas and the igniter sparks but will never light the oven.
get someone to hold a long gas match near the main burner when you try the oven . If it lights then I would suspect the igniter. even tho you can hear it snapping .
Jan 10, 2015 | Whirlpool Kitchen Ranges
On my whirlpool gas range only 1 burner out of 5 will ignite. oven light works, oven ignites. only 3 months old and worked fine until now.
Most often when cleaning, soapis left behind and obstructs the flow of ignition gas normally directed at the exact point of the spark. Check this area and use a small wire brush to clean these area of the burners that do nto work. Let us know if this helps. Eric Campion
May 19, 2012 | Whirlpool GFG461LVS Stainless Steel Gas...
Gas does not ignite/click on while trying to bake
The problem most likely is with the igniter that lights the burner for your oven. I have just written a tip on that subject. You can view that here.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 18, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
The oven pilot is out. The ignitor still works and the burners on the top of the stove still work. Tried to maually light pilot with match from the back of the broiler and it doesnt light
MOST modern appliances that use gas ignition (including dryers) no longer use a pilot. These appliances are equipped with a burner assembly with an electric igniter. The model number you have this question listed under is configured this way. The following link explains igniters and how to access the them on a gas range:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you are having ignition problems with one of the oven manifolds (bake or broil), it may be a simple matter of a weak or bad igniter. Just because an igniter glows, does not mean it is good. If the igniter is weak, the gas safety valve will not open and gas will not flow. So...attempting to light with a match will not work. If BOTH manifolds are experiencing the same problem, you may have a bad regulator or electronic oven control (EOC) board. The EOC controls all your oven features.
The surface burners use an electrode type igniter for ignition. There is one mounted next to each surface burner assembly. They get their electric source from a spark module. If none of the surface igniters are working, you may have a bad spark module. If one single burner is not igniting, the problem is probably the electrode.
If you require additional assistance, please let me know. If your model number is different form the one listed, please post back with your correct information so that I may assist you better. The model number should be located on a name plate around the oven door, or lower drawer opening. Some manufacturers place the model number on the back of the operator console.
If you have any questions, please let me know. I hope this is helpful to you.
Nov 10, 2009 | Tappan TGF320 Gas Kitchen Range
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
if you have 120 v to ignitor then ignitor is bad.
Dec 26, 2008 | Kitchen Ranges
Converted to LP Gas,How to adjust top & bottom flames in oven?
Open the air vent to the burner, you may have a small delate when it goes on , make sure the burner is clean buy the ignition, or the ignitor it's goin bad, you will know that when the oven takes more then a minute to ignite.
Nov 19, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kitchen Ranges Logo
244 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
