Question about Samsung HCL4715W 47" Rear Projection Television
Help me fix my 60 inch projection samsung
Pcl54115 60 inch samsung tv starts but shuts itself off. The three tubes starts but then kicks off
  • Samsung Master
  • 8,617 Answers
Try unplugging the three convergence yoke plugs then try powering up the set if it powers up the Convergence ICs are bad and will need replacement.
Posted on Jul 25, 2008
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Phillips 60p8341 60 inch. can not adjust sharpness shows in 3d Color is fine just sharpness is bad.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 13, 2011 | Philips 60P8341 60" Rear Projection...
On the right side of the tv aprox.3-4 inches wide down verical its black. It`s like the screen shifted left??
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 23, 2011 | Hitachi 60SDX88B 60" Rear Projection...
My sony kdf-60wf655 keeps shutting off on its own.what is the problem and can i fix it myself
If tv turns back on itself after shut down then it is weak lamp problem, replace lamp in tv to fix its problem.
Buy Sony original lamp for good picture in tv and replace it as it is user level repair and lamp replacement procedure is mentioned in related user manual.
If standby light start blinking after shut down, let me know how many times it blinks after three second pause to provide you info about possible cause of problem.
Thanks.
Dec 06, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
Magnavox 60 inch TV
  • Screen looks 3D
69189a5.pngSOLUTION
Sep 12, 2008 | Philips 60P8241 60" Rear Projection...
TV Shuts off by itself
If you are lucky, it's only a blown fuse. Some tv's this large have more than one fuse, so look real hard and find all fuses. If fuses are good, then about 95% of the time, when you have no picture/no sound, the problem is a bad H.O.T. This is a large transistor with three pins soldered into the main board and is very easy to find because it is connected to a metal "heat sink". Look for a large red or black wire coming from the pic tube down to the main circuit board (sometimes it's blue, but it's the only wire coming from the GLASS part of the tube to the board. This wire goes to about the largest component on the board called the "flyback transformer". It is usually black and is about 3 or 4 inches tall, 2 inches wide, and 2 inches thick. The h.o.t. will usually be located in the area of the "flyback". The h.o.t. will be screwed with one screw or clamped onto a large piece of metal (usually silver). This piece of metal is usually about 2 inces square and is about 1/8 of an inch thick and is mounted perpendicular to the main board. Imagine a slice of bread standing on one side rather than lying flat and this is what the heat sink looks like. Sometimes you will see several heat sinks with transistors screwed into them, but the one you are looking for will always be the largest transistor with three pins. Don't forget to unplug the tv before you begin and stay away from the large wire coming out of the tube going to the "flyback". Do NOT unplug this wire from the tube. It can shock you very badly EVEN WITH THE TV OFF FOR SEVERAL DAYS. Just be careful and go ahead and give this a try. You can do it, and this is probably going to fix your set. If not, then replace the flyback transformer. The H.O.T. is about $10 or $15 and the flyback can be from $30 to $80. It is possible that none of this will fix your set, but you have about a 95% chance that it will and with such a big and nice and relatively new set, I would give it a shot. Keever
Dec 30, 2007 | Philips 60P8341 60" Rear Projection...
Zenith rear projection television
need to take the unit to or have a repairman visit for a proper diagnosis. causes for shutdown can be many.
Aug 09, 2007 | Zenith IQB56W10 56" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
