Question about Nu Mark Numark Cdx Table Top CD Player CD Player
Numark cdx when i press the start button the platter slowly drags until it builds up to speed. If i turn the motor off for the platter, the music starts fine.
  • rlarge1 Jul 28, 2008
    Yes!!! That was it, i've had these tables for about 2yrs. and always thought that the 2 dials were the same, for the break as the 2 pause buttons are the same. I really need to get into these tables a little more.
    Thank You
Have you checked the brake and start up settings they are the dials by the start and stop buttons it it is turned too far the platter will start up slow, you just trun to dial till you get the right start up speed you want
Posted on Jul 28, 2008
Cdx platter doesnt spin ??? what parts could be the problem ?
2 possible causes:
Motor Controller PCB: http://ep.yimg.com/ca/I/yhst-15436568105612_2102_25839247
Or motor itself: http://ep.yimg.com/ca/I/yhst-15436568105612_2102_63389888
You may be able to visually tell if there is a smoked resistor on Controller board.
Apr 24, 2010 | Nu Mark Numark Cdx Table Top CD Player CD...
Start/stop button doesn't move platter
nakered switch then needs replacing
Aug 07, 2009 | Numark Pro TT-2 Turntable
Numark tt1625 turntable wavey sound
Your belt is probably worn and needs replacing. Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
May 28, 2009 | Numark BATTLE PAK v.4 Turntable
Numark TT1 need to be manually started by moving platter
that'll be a blown component of some sort on your main board i think mate,youll wanna get some one handy wiyh a multi meter.gd luck
Feb 22, 2009 | Numark Pro TT-2 Turntable
Speeds up and Slows down on it's own.
since you have a direct dirve, your motor speed control circuitry is likely failing. The only other chance is some dried up grease dragging on the platter and thus the motor but this is unlikely un such a young turntable.
It will probably be cheaper to replace than to repair this problem...
Jan 20, 2009 | Numark TT200 Turntable
How do I remove the Numark TTX platter
Nope, nothing to it. The platter is just held down by gravity. Take a mallet or a piece of 2x4 block, and give the spindle a little whack. Not too hard, just enough to break the hold.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Jan 04, 2009 | Numark TTX1 Turntable
Numark cdx
I'm sorry to tell you this, but my advice would be to buy a pair of Pioneer CDJ-800s or CDJ-1000s
I can't see the 800s costing you much more that what paid for the Numarks, and there's a reason why the Pioneers are used extensively in nightclubs, and the Numarks aren't.
Mar 20, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Platter spins very slowly
Well hope fully its something small. check your pitch control first make sure its not set at a slow speed. then check your start stop knobs at the bottom of the table. roll them one way then start it see if that works, then the other way... if its not that then its possibly its a malfunction ,, Numark with there new awesome products but sometimes faulty that turntable wigs out goin slow then normal then slow ect... If its less then a year send it in it is coverd by warrantee
Oct 07, 2007 | Numark CDX Turntable
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
146 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
robert landry
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
