Question about Vacuums
Bissell - bissell platinum 2 proheat powersteamer 1699 p
Hello, I borrowed this unit from a friend and cleaned it to familiarize myself with it and downloaded the manual.
I filled the bladder filled and the soap tank. I started the unit and when I push the handle trigger no solution comes out. could there be a clog somewhere?
I checked the flow meter screen it was very clean like it never saw any solution.
I also did what you suggested and removed the inspection door for the pump belt and it was ok however when I started the unit with the inspection off to see if I could see fluid travel down the tube, I confirmed it did in fact show fluid moving. It appears the pump is working, any other thoughts?
Anthony
  • dvassist Jul 31, 2008
    Thank you for responding I appreciate it.
    Sorry the model is the 1699 p Bissell platinum 2 proheat powersteamer.
    President:
  • 1,673 Answers
Hard to determine for sure without the model number. Does water squirt out of the hose? If it does then the heater in the heater in the handle may be clogged, if you model has this. Is the top cover and bottom together at the back of the cleaner, if not then water can't flow from the tank, and is the gasket on the valve on the bottom of the tank? Other wise it could be a bad pump.
Posted on Jul 27, 2008
  • Lauren Junge
    Lauren Junge Jul 31, 2008
    But does water squirt out of the hose handle when you squeeze the handle?? If it does then the heater in the handle may be clogged.
I need a diagram of the hose connection in a Bissell Proheat model 1699-r
Bissell Proheat Carpet Cleaner Parts & Repair Diagrams
www.vacpartswarehouse.com > BISSELL
The Bissell Proheat Series Vacuum Parts, Repair Schematics, & Accessories. ...Bissell Proheat Proheat Cleaner 25A3 ... Bissell Proheat Deep Cleaner 1699 ..
Aug 30, 2015 | Bissell Vacuums
Bissell powersteamer will not dispense water
calcium deposits from hard water... run vinegar and hot water through it a few times.
Mar 19, 2013 | Bissell 1699 ProHeat Clear View Upright...
I purchased my Bissel PowerSteamer Clearview a few years or so ago, and cannot find where I filed the manuals. If I find the actual seriel number on the Bissel PowerSteamer Clearview, Is there a way that I...
No need my friend. Go here. All documentation is here...and....it's free! Hope this helps : )
http://www.bissell.com/user-guides/?searchtext=1699%2520pro%2520heat&searchType=search&mode=228
Jan 07, 2011 | Bissell 1699 ProHeat Clear View Upright...
My Bissell Proheat Powersteamer Plus isn't dispensing the cleaner or water, what's the solution/
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Apr 15, 2010 | Bissell 1699 ProHeat Clear View Upright...
Looking for a bissell powersteamer pro heat carpet cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
zvnb
Jan 04, 2010 | Bissell 1699 ProHeat Clear View Upright...
Can a bissell powersteamer work if the belt on the
heatman101
retr
Nov 17, 2009 | Bissell 1699 ProHeat Clear View Upright...
How to operate bissell carpet cleaner.
Look at the Bissell web site. You can enter the model number and get the operator's manual for Bissell products.
May 27, 2009 | Bissell 1699 ProHeat Clear View Upright...
How to operate a Bissell Powersteamer Model 1699p
heatman101
gjk
Apr 05, 2009 | Bissell 1699 ProHeat Clear View Upright...
Help
this page should solve the problem
http://www.vacuumcleanershop.com/Bissell_proheat_powersteamer_mod.htm
Nov 24, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Vacuums Logo
186 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
