Question about Sony PlayStation 2 (PS2) Console
Disc tray my ps2 doesnt really work good. when i put in a cd the browser configuration comes up how do i fix that. thankyou
  • audibest Jul 26, 2008
    its a phat one
  • audibest Jul 29, 2008
    thanks man great it worked thank you awesome
  • 135 Answers
Is your PS2 a slim or a phat one?
Posted on Jul 26, 2008
  • Israel Beswayan
    Israel Beswayan Jul 29, 2008
    Either the lens of your PS2 needs cleaning or the pins of the spinner of your tray aren't that properly hooked on the disc (that happened to me a lot, heheh) and the disc isn't being read properly...just be sure when you put in the discs on your PS2, the pins of the spinner are locked on place(meaning they shoul be sticking outof the hole of the disc)...
Ps 2 disc wont turn
I had this same issue with my PS2, honestly I think it was something to do with the laser eye reader that reads the disc, when it is dirty the disc won't even spin or attempt to read it.
you can either take an air compressor and when the ps2 is off, have the disc tray open and blow the dust out of it.
Or, i personally would take the ps2 apart and clean the diode itself with some rubbing alcohol. Just don't void your warranty or somehow break it.
This article will help you with disassembly: http://arstechnica.com/gaming/guides/2003/11/ps2-repair-guide.ars Hope this helps!
Mar 18, 2009 | Sony PlayStation 2 (PS2) Console
Will not load some games
I had the same problem with my ps2. I found a solution that might help you. take a Q-tip and dip it in rubbing alcohol or water just intil damp. gently clean the eye and the rest of the disk tray. then dry it the other end of the Q-tip. when the eye dirty with dust or a hair or a small speck of paper or plastic from a disk will slow the ps2 down when loading. hope this helps!
Feb 13, 2009 | Sony PlayStation 2 (PS2) Console
Disc doesnt spin, ps2 slim
Does this problem apply to ALL of your discs? If not, then first, when putting your discs in the tray, be sure that ALL of the three PINS on the tray that holds the disc are locked in place, meaning they should all be sticking out on the hole of your DVD. This happened to me a lot...heheh...then, if this problem apply to all of your disc, There probably is a problem with the lens of your PS2...either slim or the fat one...then the only solution is to have your lens replaced...sorry, but i don't know how much it cost now...
Jul 21, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 will not read disc
Check your disk for scratches fingerprints ect,,
if thats all good step two
try useing a lens cleaner
****(( tip and trick for scratched disks ))****
a crayon rubbed on the disk then wiped off with a lint free cloth
no t-shirts dish towels that will just add more scratches
remember start at the center wipeing out to the edge.
if none of that works you may have a lens problem
Jan 04, 2008 | Sony PlayStation 2 (PS2) Console
Disc wont work
Hi AdalVI,
Your PS2 probably has a dirty laser lens. Below is a procedure for cleaning the lens on the big PS2. It does not work on the Slim PS2. Do not ever use alcohol on a slim PS2 laser lens.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Won't read disc.
Hi Crashley41 and Von281,
Since you have the bid Phat mode; you will have better luck at fixing your PS2.
This is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
If you still have trouble reading discs. Click on " Repair Directory" at the bottom of this screen. Then on the next page click on "Video Game Consoles". Pick a Repair shop to get your PS2 repaired. Fixya has some good ones dedicated to Playstations.
Nov 23, 2007 | Sony PlayStation 2 Slimline Console
My PS2 NEEDS HELP!!!
hi can you ask me in a experts live chat so i can go through it please ? thanks
Nov 12, 2007 | Sony PlayStation 2 (PS2) Console
My ps2 wont read any discs but it plays music discs and cd's
Hi Cozza,
Open the console up, and remove the cover over the Cd drive. Clean the lens of the Laser with a Q-tip lightly dampened with Rubbing alcohol. Use the dry tip of the Q-tip to dry the lens, look to see if you left any lint, and make sure the lens of clean.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Wont Play
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Oct 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
