Question about Sony Playstation 3 (PS3) Console
PS3 When i turn on my ps3 its just a blank screen all my cords are connected to my ps3 to the tv but nothing shows up on my screen.
  • 344 Answers
Hello. There are a few causes for this. I will list acouple solutions for you.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
2. If option 1 does not work call Sony because the video out chip has blown or come unsoldered.
I hope this helps. Good luck to you.
Posted on Jul 26, 2008
I turn the ps3 on but the video doesn't appear. i checked the tv and cords and nothing was wrong with them.
Did you check that the AV cords are plugged in right? Red to Red, White to White, Yellow to Yellow? Are they properly connected in the back of the PS3 not loose connections? It could also be that the PS3 display settings are at a really high resolution for your T.V. Try reset the PS3 resolution settings back to factory settings by turning the PS3 off and then hold down the power button for 3-5 seconds and you will hear some beeps it will load your PS3 resolution at 480i. Should give you your screen back.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 start screen will not show up on my TV
I had this problem before. I messed with the settings on my PS3 and My TV until the settings matched. My PS3 would show the home until I loaded a game. I turned off then on my PS3 to get to the settings. My TV manual had the types of videos it supported so I went with the second to highest setting it supported and it worked. Hope this helps.
May 29, 2009 | Sony Playstation 3 (PS3) Console
TV Blank when powering PS3
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turns on, but does not show nothing on tv, game is inserted
Hold down the power button until you hear 2 beeps. It should reset the video.
Mar 23, 2009 | Sony Playstation 3 (PS3) Console
MY PS3 BROKE
buy a new aux cord for it or the aux hookup in the tv or the playstation could be bad hope this helps
Nov 19, 2008 | Sony Playstation 3 (PS3) Console
Ps3
try holding the power button for at least 5 seconds until you hear another beep.
This should reset your ps3 to default settings, but will NOT erase your data.
Also, check for any loose video connections and make sure that you are in the right video input.
Aug 23, 2008 | Sony Playstation 3 (PS3) Console
PS3 Powers but doesn't show on screen?
try holding down the power button when you switch it on, for 4 seconds it runs the optimal settings screen and selects the best option for the leads fitted. hope this helps
Jan 19, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
50 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
